Brake Swap
Old Jan 13, 2002 | 11:22 PM
jdm92accord's Avatar
Default Brake Swap
Does anyone know which car (what year and model) I could swap in all 4 disc brakes onto a 92 4dr Accord? I want to put on aftermarket brakes, but I'm having a hard time finding parts for a 92 Accord.
So, what I wanted to do is find out which car has a similar disc brake setup, and then buy parts for that car and put it onto my car.
I posted this on tech and someone mentioned the Prelude, but no year was listed. Hope someone on here knows
Old Jan 14, 2002 | 12:03 AM
IwanAturBo's Avatar
Default Re: Brake Swap (jdm92accord)
90-93 accord SE.. they have all 4 disk wif ABS... try that..
Old Jan 14, 2002 | 03:09 AM
urbanlegend21's Avatar
New User
yuo could actually upgrade to bigger rotors and calipers if you want itlizing accord wagon rotors and calipers
Old Jan 14, 2002 | 11:12 AM
What I was thinking was what other car (Prelude, Integra, Civic?), could I swap in brakes for. I tried looking around for aftermarket brakes for the Accord, but was very limited, other models like the civic offer more in terms of different manufacturers.
Old Jan 14, 2002 | 11:15 AM
SOHCArchangel's Avatar
upgrade to the larger accord wagon/v6 rotors/calipers i did this, you cant do teg/civic/lude b/c they use floating rotor design, accords 5th gen and 4th use hub pressed over rotor
Old Jan 14, 2002 | 06:04 PM
Gennady's Avatar
New User
Default Re: Brake Swap (SOHCkordVTEC)
Didnt someone swap in either Oddyssy rotors and calipers or the ones from the 3.5 RL?
How hard was the swap from the wagon/V6 that you did SOHC?
Old Jan 14, 2002 | 06:53 PM
Well, let me ask this instead , which car (year and model?) can I swap in the rear discs?
Old Jan 14, 2002 | 06:57 PM
I would like to find out from what other car(other than an Accord) can I swap in the rear discs with(Integra, Civic)?
Old Jan 20, 2002 | 09:21 PM
forcefed's Avatar
i've never seen a straight answer
Old Jan 21, 2002 | 03:29 AM
New User
the reason no one answers is because to do this is a waste of money, your car doesn't use its rear brakes nearly as much as the fronts and the last thing you want to do its have more rear brake under extreme conditions
all other applications for brakes are rotor over hub design on the front so a complete front suspension swap will need to take place to change out to different honda application
the rears willl depend on lug pattern
if you want bigger brakes or more braking upgrade your fluid and pads first, that should be all you need
do you iontend on using stock accord calipers?
Old Jan 22, 2002 | 03:30 AM
New User
Default Re: Brake Swap (urbanlegend21)
to the top
Old Jan 22, 2002 | 06:41 AM
4doorH22's Avatar
If your Accord doesn't already have rear discs, you can swap the rear brakes from these 4th generation Accords: the aforementioned SE, 92-93 EX, and the 92 Anniversary Edition. Like Morgan said, the benefit won't be worth the investment, but rear discs do look a look cooler than drums.
As for the front brakes... I am 2 inches away from doing the V6/wagon swap Misa did, but I'm holding out just a bit to see what Morgan comes up with (something like using a Prelude knuckle/hub/floating rotor). What's up with that Morgan? I've changed enough Accord brakes now that it isn't much of a problem, but it sure would be nice to be able to change front rotors by just removing 2 screws instead of having to remove the spindle nut, pop out the hub, unbolt the rotor... you know the routine...
Old Jan 22, 2002 | 07:09 AM
New User
Default Re: Brake Swap (4doorH22)
Time, man, time!
I will do it this weekend if it is nice out, I promise
Old Jan 22, 2002 | 07:18 AM
4doorH22's Avatar
Oh have you already got the parts? Prelude knuckle and stuff?
Old Jan 22, 2002 | 12:02 PM
What year and model Prelude is the parts from?
Old Jan 22, 2002 | 12:03 PM
New User
93 VTEC model hopefully, I have to put a couple of calls out tomorrow
Old Jan 22, 2002 | 12:12 PM
Let me know how it goes, I am interested in doing the swap. If you could email me that would be appreciated.
Old Jan 22, 2002 | 12:17 PM
New User
trust me I will let everyone know how it goes
4doorH22's Avatar
Corey's not driving his racecar much is he? Are you gonna try swapping his knuckle in? The entire knuckle assembly with rotor and caliper attached. See if the control arms, radius rod, tie rod, etc line up. You could try that then put it right back on his car.
If it fits, get some salvaged knuckles and do the conversion, if not, back to the drawing board...
Old Jan 22, 2002 | 12:25 PM
New User
not a bad idea, I will confer with him about it
Old Jan 22, 2002 | 12:52 PM
John's Avatar
New User
haha... "borrow" Corey's wheel knuckle assembly and such...
what ever happened to FastBrakes intention on producing a brake kit for the 5Gs?
Old Jan 22, 2002 | 12:57 PM
New User
Default Re: Brake Swap (DunReit)
probably not enough intrest in it now that we have gone on this conversion kick
Old Jan 22, 2002 | 07:06 PM
Honda318dx's Avatar
hell morgan, lets do one side, if it bolts up, it may need an alignment, but if it bolts up, and goes up and down with no binds, then we know it will work.. hell, lets do it this weekend, take some measurements, and go from there..
Old Jan 22, 2002 | 07:23 PM
smokin rubber's Avatar
Default Re: Brake Swap (Honda318dx)
You are going to do everything, all the control arms, what bushings will you use? Have you measured the space between lower control arm mounts and stuff?
Old Jan 22, 2002 | 07:58 PM
Honda318dx's Avatar
Default Re: Brake Swap (smokin rubber)
we will find out this weekend.... If morgan is up to it....
