Anyone have DIY gauges into dash install?
Old Jan 27, 2005 | 12:45 PM
BDogggUT34's Avatar
Default Anyone have DIY gauges into dash install?
Has anyone seen a write up or DIY on installing boost/temp/oil etc.... gauges into an EG dash (the area right above the glove box) ?? Like tools to use, techniques to not screw up the dash, things to remove or look out for before cutting...etc... things like that.
Old Jan 27, 2005 | 12:49 PM
Luserkid's Avatar
Default Re: Anyone have DIY gauges into dash install? (BDogggUT34)
You could do it one of 2 ways.
1. use a dremmel
2. Use a drill with a hole bit, the size of your gauge.
Then run the wires like normal. Just make it a little smaller hole then your gauge so it stays.
I did this one with a dremmel:
Old Jan 27, 2005 | 12:51 PM
BDogggUT34's Avatar
Default Re: Anyone have DIY gauges into dash install? (Luserkid)
is there anything directly behind that area to look out for before drilling?? thats exactly what i want by the way, that looks good!!
Old Jan 27, 2005 | 12:52 PM
litterbox's Avatar
I am a (Trial User) Army
I believe there is space behind that part of the dash so you won't run into anything when you cut. The heater core is behind it but you have room to work with. I would just take exact measurements then make a template on paper and line that up then do what Luserkid says.
Old Jan 27, 2005 | 12:56 PM
Luserkid's Avatar
I did mine right there, and can garentte theres nothing behind there. The piece under i think has some hard stuff there that youll have to get around, but dont quote me this is off the top of my head.
Old Jan 27, 2005 | 01:00 PM
Mrfeee1's Avatar
[QUOTE=Luserkid]
SHAME ON YOU!!!!!! that looks like S#!t !!!! what were you thinking!!!!! Gauge aint even straight.
Old Jan 27, 2005 | 01:06 PM
Luserkid's Avatar
Default Re: Anyone have DIY gauges into dash install? (Mrfeee1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrfeee1 &raquo;</TD></TR><TR><TD CLASS="quote">
SHAME ON YOU!!!!!! that looks like S#!t !!!! what were you thinking!!!!! Gauge aint even straight.</TD></TR></TABLE>
This i know that was my first time doing one and i did it with a hand drill. The reason why the gauge isnt straight is because if it was i wouldnt be able to read 0-40 Its a oil pressure gauge and has to be tilted.
Old Jan 27, 2005 | 01:11 PM
BDogggUT34's Avatar
i think thats what i'm tryin to avoid
Old Jan 27, 2005 | 02:17 PM
Luserkid's Avatar
Just use a dremmel and take your time, and make sure (if using a drill bit) that it doesnt get stuck in the material (like what happened to mine). But as you could see for my 2nd one (first pic i showed) it came out perfect.
Old Jan 27, 2005 | 02:22 PM
nocturnaldragon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
This i know that was my first time doing one and i did it with a hand drill. The reason why the gauge isnt straight is because if it was i wouldnt be able to read 0-40 Its a oil pressure gauge and has to be tilted. </TD></TR></TABLE>
Ohhh come on look at that, he clearly photoshoped that in to show you what not to do obviously no one with a post count that high would do anything silly like that.
Old Jan 27, 2005 | 02:49 PM
HybridHatchC1's Avatar
Default Re: Anyone have DIY gauges into dash install? (nocternaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon &raquo;</TD></TR><TR><TD CLASS="quote">
Ohhh come on look at that, he clearly photoshoped that in to show you what not to do obviously no one with a post count that high would do anything silly like that.</TD></TR></TABLE>
LOL and look in his sig...
"Need work done for a cheap price in the So Cal Area?
Electrical, engine/turbo work, transmission work, any car.
PM me"
HAHAHAHAHAHA, but seriously use a dremel take your time and cut away small amounts and test fit... to get that perfect fit. Please for the love of god don't just attack it and cut it out to the guage size.
Old Jan 27, 2005 | 02:55 PM
BDogggUT34's Avatar
Default Re: Anyone have DIY gauges into dash install? (HybridHatchC1)
i love dremmels!! thanks for the advice
Old Jan 27, 2005 | 03:03 PM
93civiceg6's Avatar
that looks kind of bootleg
Old Jan 27, 2005 | 04:08 PM
AWDxBOOST's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">You could do it one of 2 ways.
1. use a dremmel
i did this too a while ago
Old Jan 27, 2005 | 04:20 PM
vtec69's Avatar
Didi you drill that hole with your eyes closed???
I did mine right there, and can garentte theres nothing behind there. The piece under i think has some hard stuff there that youll have to get around, but dont quote me this is off the top of my head. </TD></TR></TABLE>
Old Jan 27, 2005 | 04:35 PM
t57b18's Avatar
i used a hole saw dit and a drill and i also bought a set of the auto meter angle rings so you can angle the gauges to your veiw good luck and take your time its a bi*ch to change a dash
Old Jan 27, 2005 | 05:10 PM
Spoolin93si's Avatar
Default Re: Anyone have DIY gauges into dash install? (t57b18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t57b18 &raquo;</TD></TR><TR><TD CLASS="quote">i used a hole saw dit and a drill and i also bought a set of the auto meter angle rings so you can angle the gauges to your veiw good luck and take your time its a bi*ch to change a dash </TD></TR></TABLE>
Yeah those angle rings work good.
Hawkze_2.3
Apr 23, 2012 04:38 PM
kobeballer96
Mar 31, 2009 10:17 AM
Mr.Highlife
Apr 4, 2008 05:10 AM
turbotime
11
Oct 15, 2006 10:29 AM
