got my jun3 cams installed now what?
Old Jan 13, 2002 | 10:17 PM
infinkc's Avatar
Default got my jun3 cams installed now what?
finally got my head built up. Skunk2 valves, spoon headgasket, jun valve springs, jun3 cams, portflow retainers. What are good settings to put the cam gears at? right now i have them at 0 0. Also i have a mugen ecu, will this hurt performance if i use this ecu? cause of the 4500k vtec xover. Also should i be running any fuel upgrades? ill i have now is a hi flow pump. thanks!
Old Jan 13, 2002 | 10:23 PM
NAB20C5's Avatar
Default Re: got my jun3 cams installed now what? (infinkc)
Go to the dyno and get a Vafc, as far as the mugen ECU, on an ITR modded w/ the same ECU and I/H/E it was a little rich at the low end and lean at the top, so that's my suggestion...and maybe a FPR....and go from there...best wishes, Eric
Old Jan 14, 2002 | 05:59 AM
Mike K's Avatar
Default Re: got my jun3 cams installed now what? (NAB20C5)
Leave the cams at 0.0 until you get to the dyno.
All the JUN3 cams I have tuned haven't liked much degreeing. Best run on Mike M.'s car was -1 intake, +2 exhaust.
B2FiNiTY
Jun 4, 2002 06:51 AM
mikeyz
Feb 7, 2002 09:16 PM
Malice
Jan 15, 2002 05:16 PM
GSlowR
Sep 7, 2001 08:30 PM
Jaisun
Jun 18, 2001 01:04 PM
