SPC Front Camber kit, installed - NEW
Old Jan 27, 2005 | 10:40 AM
Austin's Avatar
Default SPC Front Camber kit, installed - NEW
SPC – Front camber kit,
Retail of $479, actual street price is mid-high $300 range
Here is the link of when I first took pictures of the product last year when it was still going through some heavy R&D Road Race/Autocross forum and Type-R forum
Since the part is fairly new, I called SPC for the specific part number, and had a local vendor order it up for me…Chuck’s Brake & Wheel in Santa Rosa, CA great guys and they’re the NASA tech station too.
The part is made of Aluminium, and then is shaved down to reflect left, or right hand side parts. Since I received one of the first parts, there weren’t any part numbers on them to reflect which part was left/right side…it’s fairly evident when you pull out one of the stock pieces and compare them side by side to know which side belongs where. This part is a little on the pricey side, but with the fit and finish of the part, and the available uses I find that it’s well justified.
Installation – it was fairly easy, pull suspension out of the way, remove the old one, install the new one.
Adjustment nut on the top – 27mm
Torque spec – 120 ft/lbs
Adjustment – camber and caster can be adjusted at the same time
Camber adjustment - camber is fairly easy to adjust just loosen the top bolt(the hard part, we had to disconnect the upper ball joint to get the bolt low enough to get a 27mm wrench in there), and move it to where you want it to be, and snug it up, put a wheel back on, and check your alignment.
Caster Adjustment – same as above, but you have to remove the ball joint, and move the disc to a new position to either gain, or lose caster.
Directions –
Here are the pictures:
Modified by Austin at 11:54 AM 1/27/2005
Modified by Austin at 12:44 PM 1/27/2005
Old Jan 27, 2005 | 10:41 AM
Bbasso's Avatar
Default Re: SPC Front Camber kit, installed - NEW (Austin)
Beefy looking part!
good review!
Old Jan 27, 2005 | 10:42 AM
ZygSpeed's Avatar
Looks like a really nice/well made piece.
Old Jan 27, 2005 | 10:49 AM
Bradstard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin &raquo;</TD></TR><TR><TD CLASS="quote">
Why do you have lotion right next to your computer?
Old Jan 27, 2005 | 10:52 AM
Austin's Avatar
Default Re: SPC Front Camber kit, installed - NEW (Fat Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">
Why do you have lotion right next to your computer? </TD></TR></TABLE>
It's in the garage, and it's not my garage...
Austin
Old Jan 27, 2005 | 10:53 AM
Bbasso's Avatar
He's got dry skin.. that's all
as long as there is no box of tissues
Old Jan 27, 2005 | 11:00 AM
Nishant's Avatar
Default Re: SPC Front Camber kit, installed - NEW (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">He's got dry skin.. that's all
as long as there is no box of tissues </TD></TR></TABLE>
ewww i did not want to hear that *puts in ear plugs*
Old Jan 27, 2005 | 11:05 AM
jdmspoonitr's Avatar
Default Re: SPC Front Camber kit, installed - NEW (Nishant)
HAHAHAHH LOL....that ain't Austin's garage LOL.....LMFAO
ANyway that ish does look beefy! Hmmmmm......and that ball joint is ******* huge man!
Old Jan 27, 2005 | 11:20 AM
Chris N's Avatar
Default Re: SPC Front Camber kit, installed - NEW (jdmspoonitr)
Approx Price?
Thanks Austin
Old Jan 27, 2005 | 11:38 AM
RTW DC2R's Avatar
looks like a very nice part, much more beefy than my JUNK2's. and I like the caster adjusting abilities I might have to look into these.
Old Jan 27, 2005 | 11:44 AM
Austin's Avatar
Default Re: SPC Front Camber kit, installed - NEW (Lancydosa H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lancydosa H &raquo;</TD></TR><TR><TD CLASS="quote">Approx Price?
Thanks Austin </TD></TR></TABLE>
Price listed at the top of the page.
Austin
Old Jan 27, 2005 | 12:34 PM
SpoonR617's Avatar
Nice part!
Old Jan 27, 2005 | 06:35 PM
RPM's Avatar
RPM
How much do they weigh vs the stock units? Nice piece
Old Jan 27, 2005 | 07:29 PM
97 TYPE-R 312's Avatar
Default Re: SPC Front Camber kit, installed - NEW (RPM)
thanks for the review! I'm going to be getting a set of these for the R and the EP soon.
-Victor
Old Jan 27, 2005 | 08:58 PM
TurblowR's Avatar
Default Re: SPC Front Camber kit, installed - NEW (97 TYPE-R 312)
that huge nut on the ball joint is going to bang up your fender if your car is lowered. how do i know. i put one on a customers car and it banged the **** out of it.
Old Jan 27, 2005 | 09:08 PM
Default Re: SPC Front Camber kit, installed - NEW (TurblowR)
how low was it and on what type of vehicle?
-Victor
Old Jan 28, 2005 | 08:50 AM
vain's Avatar
curious, how low are you riding?
Old Jan 28, 2005 | 08:52 AM
Austin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97 TYPE-R 312 &raquo;</TD></TR><TR><TD CLASS="quote">how low was it and on what type of vehicle?
-Victor</TD></TR></TABLE>
I would also like to know what suspension was being used, as I do not have any issues with it on my car, and I've been driving for the last month with them installed on mountain roads of Northern California, and hitting most of the pot holes while I've been at it. Besides which, the nut doesn't protrude from the top more than ~3/8 of an inch.
Austin
Old Jan 28, 2005 | 08:53 AM
Austin's Avatar
Default Re: (vain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vain &raquo;</TD></TR><TR><TD CLASS="quote">curious, how low are you riding?</TD></TR></TABLE>
Type-R, lowered ~3/4-1".
Austin
Old Apr 3, 2005 | 09:06 AM
Renegade's Avatar
can you give me the part number?
Thanks
PM sent
Old May 1, 2005 | 09:07 PM
silintegra's Avatar
Default Re: SPC Front Camber kit, installed - NEW (Renegade)
where can i get this kit?? i couldn't find it in the SPC website.....????
Old May 2, 2005 | 08:25 AM
Black R's Avatar
25 Year Member
The street price sounds very close to that of the J's roll center adjusters.....
Did you max out your caster settings?
Rionmann
Suspension & Brakes
Feb 3, 2006 05:48 AM
gospeedgo1
Jan 23, 2006 09:54 AM
fireant
Suspension & Brakes
Mar 26, 2005 06:48 AM
Austin
13
Feb 5, 2005 11:30 AM
bryandamatrix
Jul 18, 2004 01:00 AM
