Alternator
i have a question if you remove the master cylinder from the brake booster(to get the alternator out) it lets like air out what does that mean--
did i just f up something and if so how do i fix? Thanks for the info.
Modified by kaotikcrx05 at 7:17 AM 1/27/2005
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">Not sure what happens there.. You can get the alternator out without removing the brake booster..</TD></TR></TABLE> Yeah really. I think it just let out the pressure in the brake system. Bleed the brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote"> You can get the alternator out without removing the brake booster..</TD></TR></TABLE>
Yup..take off the lower alternator bracket and slide it out underneath..Both ways are a pain in the ***..
you can remove it from under. i asked the same question a long *** time ago
edit: hope this helps https://honda-tech.com/zerothread?id=693422
lrcrx90
22
Dec 23, 2006 08:42 PM
daemoan
12
Jan 31, 2004 05:24 PM
unknownhero16
Dec 27, 2003 05:41 PM
