Scrape on H22 block
Old Jan 27, 2005 | 03:57 AM
93H22ACX's Avatar
Default Scrape on H22 block
I just picked up a H22A4 block for the crank. Got it really cheap.....but i would like to know if the block is still reuseable. It has two deep cuts on the block. Here is the pictures.....let me know what you guys think...yes reusable or no not reusable...
Old Jan 27, 2005 | 06:06 AM
tgreaves's Avatar
Default Re: Scrape on H22 block (93H22ACX)
How deep is the cut? Hard to tell from the pics but it kinda looks like a scratch on the surface..
Old Jan 27, 2005 | 06:24 AM
93H22ACX's Avatar
Default Re: Scrape on H22 block (tgreaves)
probably like .5-1mm deep
Old Jan 27, 2005 | 06:25 AM
93H22ACX's Avatar
lets say i want to use this block later on..can i fill it with something and use copper hg sprayer on the the hg to make a better seal?
Old Jan 27, 2005 | 06:27 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93H22ACX &raquo;</TD></TR><TR><TD CLASS="quote">lets say i want to use this block later on..can i fill it with something and use copper hg sprayer on the the hg to make a better seal?</TD></TR></TABLE>
I would say you would be fine with using copper spray on that.. Only thing that scares me is that the crack might spread..
Old Jan 27, 2005 | 06:30 AM
93H22ACX's Avatar
thats true. its not a crack if it matters. its a cut or gouge
Old Jan 27, 2005 | 06:40 AM
tgreaves's Avatar
Not sure what to tell you.. I would take it to a machine shop and have them look at it.. Or you can get it sleeved..
Old Jan 27, 2005 | 06:43 AM
93H22ACX's Avatar
yeah... i think AEBS sleeves woul take care of it
Old Jan 27, 2005 | 06:50 AM
tgreaves's Avatar
Any sleeve would take care of it..
Old Jan 27, 2005 | 07:00 AM
GDM Z28's Avatar
if its just on top take it to a machine shop and have them deck the block and see if it takes it out.
Old Jan 27, 2005 | 08:11 AM
93H22ACX's Avatar
Default Re: Scrape on H22 block (civicflnum1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">if its just on top take it to a machine shop and have them deck the block and see if it takes it out. </TD></TR></TABLE>
i thought about that but the machine shop might haev to take too much off where the piston might stick out of the hole.
Old Jan 27, 2005 | 08:15 AM
GDM Z28's Avatar
i thought about that but the machine shop might haev to take too much off where the piston might stick out of the hole.</TD></TR></TABLE>
thats y u gotta bring it to the shop n see what they say.
Old Jan 27, 2005 | 08:32 AM
mmuller's Avatar
Mad Scientist
it looks like the block could be decked to get rid of those scatches no problem; but then again, it ''looks'' like...
Old Jan 27, 2005 | 09:07 AM
93H22ACX's Avatar
Default Re: Scrape on H22 block (mmuller)
thanks for the help guys.
96AccordLX1
Dec 20, 2013 04:37 AM
turboaccord77
Feb 1, 2012 10:25 PM
snaileg
Jun 12, 2009 12:34 AM
sewell94
Jul 28, 2007 12:01 AM
TheNosR
Jul 17, 2007 05:08 PM
