*different CLusters in DelsoL*
Never got around to hooking it up, but it is in my closet, wiring isn't too difficult if you have both helms (RSX and del sol) however the temp gauge will never work along with most the idiot lights due to the RSX's multiplexed inputs (you would need to use the RSX multiplexor which is integrated with the fuse box) Also you can't roll up the RSX mileage to match your sol's milage due to the digital design.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol »</TD></TR><TR><TD CLASS="quote">
Never got around to hooking it up, but it is in my closet, wiring isn't too difficult if you have both helms (RSX and del sol) however the temp gauge will never work along with most the idiot lights due to the RSX's multiplexed inputs (you would need to use the RSX multiplexor which is integrated with the fuse box) Also you can't roll up the RSX mileage to match your sol's milage due to the digital design.</TD></TR></TABLE>
clean
clean
Im thinking that the RSX cluster conversion would be impossible
if you have ever seen the back of it... Theres only 2 plugs.. one 12 wire and a 8 i believe.. They have multivolt wires... That control a combination of stuff
6sPdSol
13
Mar 29, 2005 05:18 AM
