What year did TB's come with the FITV valve?
Yeah yeah...I searched....but the words "Throttle Body" and "FITV" returned a little over a trillion results.
I'm basically just wondering what throttle bodies came with the Fast Idle Thermo Valve under the throttle body as opposed to the intake manifold...I'm switching manifolds and would like to maintain it do to living in cold *** climate.
So im guessing u have a compatible TB now (with the lower hole for FITV) as well as a compatible IM along with the FITV itself installed. What manifold are u going to switch to? Also, just swap over your FITV "ready" TB to the new IM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 »</TD></TR><TR><TD CLASS="quote">So im guessing u have a compatible TB now (with the lower hole for FITV) as well as a compatible IM along with the FITV itself installed. What manifold are u going to switch to? Also, just swap over your FITV "ready" TB to the new IM.</TD></TR></TABLE>
No...I have a throttle body now that does NOT support the FITV (since my manifold does). I'm purchasing the AEBS manifold which does not have spots for the FITV....however, I know there were certain years (obd1???) in which the FITV is located on the bottom of the TB. These are the TB's I am trying to source inorder to retain my fist idle.
Oh ic what ur sayin. Yea a friend of mine has one layin on his garage floor right now, but i dont know what its off of.
i think i read this someone on here not positive on this but i think 99 2000 si tb's have this you should look it up see if im right . sorry its the best i can come up with just trying to help
when i got my LS swap it came w/out the FITV, i just made a block off plate for the mani and called it a day, it idles a little rough for about 30 sec when its extremely cold outside and then its fine
94+ integras ls & gsr (no itr).
not all obd1. 92-3 integras dont have it.
Modified by Eggman at 1:46 PM 1/27/2005
I talked to someone who told me that obd1 GSR throttle bodies have the valve for sure. The one I am looking at purchasing is a 99-2000 civic si TB...but I don't believe this has the spot on the TB for the FITV...so I might end up having to eliminate it. Bump to find out if it is ONLY obd1 gsr's.
I just sold a 99 SI TB and it DOES NOT have it. My 92 obd-1 GSR b17 has one, but its integrated into the intake manifold as well so thats out the window. Its gettin narrowed down...
Modified by fourthgenhatchB17 at 12:57 AM 1/28/2005
Also...right now I have an obd0 TB....so is the only difference going to be that my FITV will connect to the TB as opposed to the manifold? I don't need to get an OBD1 FITV will I?
What I'm basically asking is that FITV's all work the same way...one just does its job via the Intake Manifold....while the other does it on the throttle body, correct??? This would mean that my TB would have a single hole (for the IACV) while the TB I desire should have 2 holes (for the IACV and FITV)...right?
Modified by spankjelly at 6:44 AM 1/28/2005
Modified by spankjelly at 7:04 AM 1/28/2005
B18c1-Integra
13
Feb 22, 2008 05:34 PM
Turbo R
33
Apr 15, 2005 11:28 PM
