DC sports 4-2-1 header + 02 sensor info
Currently my '00 Si is running NO 02 sensors cause some moron took them out and I havent had the $$$ to buy everything but I do now! Just need to know, the Si uses 2 02 sensors, one in the header and one in the cat. Does the DC sports header have a spot and is it the stock location for the sensor? I'm gonna get new OEM sensors and a jackson racing CAT and want to know everything will work together before I drop $1,000 on all this stuff.
Thanks
Thanks
dc sports headers have o2 bungs in them... if u buy one for the correct application it should be pefect... also the supply the extentions for ur o2 sensor if necessary
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkrangers »</TD></TR><TR><TD CLASS="quote">whats an 02 bung? You'll kinda lost me there... is it just a filler if you dont use the sensor?
it's the actual hole that you'll be plugging the O2 sensor into to get readings off one of the pipes. my DC bung-hole (couldn't resist!) is only one of the pipes, whereas my stock header took a reading from all 4 i believe....no codes thrown, all good in the 'hood
right, if you buy the right header then it comes with a bung. if you buy lets say i think a gsr header for a b16, then the you have to make a test pipe with a bung in it. i belive so, i had a gsr header that dint' have a bung. so i made one.
Worst case scenario would be having to go to a welding shop and have a nut welded in...no big deal.
If your purchasing a header for that specific model of car, you shouldnt have an issue. Especially from DC.
kylefakesi-r
Oct 29, 2003 02:22 PM
