Why is my brake light on?
Old Jan 26, 2005 | 02:44 PM
kolohekine's Avatar
Default Why is my brake light on?
Does any one know how to get rid of this? Will it just go away? This happend today when I downshifted to pass another car on the freeway.......
Old Jan 26, 2005 | 02:46 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Why is my brake light on? (kolohekine)
there are a few brake lights.....ebrake light, the brakes themselves?
Old Jan 26, 2005 | 02:47 PM
shawn_crx's Avatar
which brake light?
the one on the cluster or the tail light?
most likely it'll be the switch.
e-brake switch - cluster
brake pedal switch for tail light.
numbnuts22715's Avatar
maybe check your brake fluid? my ebrake light came on randomly a few times before because I had less brake fluid than I was supposed to.
Old Jan 26, 2005 | 02:58 PM
4drEF's Avatar
Keyboard Humorist
Default Re: (numbnuts22715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">maybe check your brake fluid? my ebrake light came on randomly a few times before because I had less brake fluid than I was supposed to.</TD></TR></TABLE>
If your fluid is low then check your brake pads BEFORE you go topping the fluid off.
The fluid reservoiur has a float sensor in it (two wires coming off the cap) to let you know when the fluid is too low.
Fluid only gets low if you have a leak or if your pads are worn.
Old Jan 26, 2005 | 09:45 PM
kolohekine's Avatar
Sorry! Its the e-brake light on the cluster...... I checked my fluid and it was good. Maybe it will go off if I reset the ecu??
Old Jan 26, 2005 | 10:14 PM
bucketheadCRX's Avatar
Default Re: (kolohekine)
mine has been doing this too for the past couple weeks..it comes on and goes off..i'm not gonna worry with it till i feel my brakes fading or the light stays on solid
Old Jan 26, 2005 | 10:34 PM
EFB16ACRX
Guest
Posts: n/a
Default Re: (buckethead36)
Yeh, I had this light on for about 2 weeks, ignored it thinkin it was e brake light, then bam, I was going down the road, and no brakes. I had a bad master cylinder. Definetely dont take it as lightly as i did, you could get serioulsy hurt
Old Jan 26, 2005 | 11:46 PM
Default Re: (90HFB16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90HFB16B &raquo;</TD></TR><TR><TD CLASS="quote">Yeh, I had this light on for about 2 weeks, ignored it thinkin it was e brake light, then bam, I was going down the road, and no brakes. I had a bad master cylinder. Definetely dont take it as lightly as i did, you could get serioulsy hurt</TD></TR></TABLE>yikes !!! thanks for the heads up..i shall take care of this
Old Jan 27, 2005 | 06:40 AM
EFB16ACRX
Guest
Posts: n/a
Default Re: (SloS13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloS13 &raquo;</TD></TR><TR><TD CLASS="quote">Take your foot off the pedal. problem solved.
I'll reiterate. I've heard people talk about brake fluid leaks like they were nothing important. Thats the single most important fluid in the car and there's never an excuse for a drop to show up missing. </TD></TR></TABLE>thats exactly it, i had no leaks, reservior was full, worked fine. I was leaving a car meet one night, and went hmm, my brakes feel a bit soft. Ah well, probably just got some air in the lines from all the racing on teh way there. Nope. The pedal went all the way to the floor. Finally got stopped after some large downshifts, and checked fluid, none there, had it towed home, and sure enough, all the paint on the firewall gone from where the fluid seeped out between the mc and brake booster. And I thought it was jsut cable stretch in the ebrake mkaing the lgiht stay on. Now, I got lucky, and was able to get off the road safely. you may not be. This is not something to take lightly
Old Jan 27, 2005 | 04:44 PM
kolohekine's Avatar
Hmmmm..... Thanks! I guess I am going to have to rip **** apart again lol
Alfspeed
Honda CR-V & Element
Aug 26, 2010 09:34 AM
hatch96y7
Oct 26, 2007 08:08 AM
93civciv
Mar 5, 2006 06:02 PM
Understeer
Dec 1, 2003 09:40 PM
Proper
Jul 26, 2002 05:57 AM
