HELP!!NO START!!
Old Jan 26, 2005 | 01:19 PM
oldschoolfreak's Avatar
Default HELP!!NO START!!
alright heres the deal i have a no start problem. when i turn the key i have plenty of battery power and everything except it just clicks no turning over or nothin. no its not the stater thats what i thought but i replaced it and its still the same thing and i have no clue now. like i said i have plenty of battery power but it just clicks. im off to work now so just leave some ideas and ill be on later. i would appreciate so help thanks.
Old Jan 26, 2005 | 01:53 PM
hybridem1's Avatar
Default Re: HELP!!NO START!! (oldschoolfreak)
i would check your starter and ignition signal fuse's....then i would start tracing power and ground from the ignition switch to the starter
Old Jan 26, 2005 | 01:56 PM
93_cxEG's Avatar
hey you should try checking out ur distributor and see if it spark...if it doesn't spark it may mean that u need a new one or maybe u neet to fix the rotor inside of it....
Old Jan 26, 2005 | 02:03 PM
hybridem1's Avatar
Default Re: HELP!!NO START!! (93_cxEG)
i don't think it would be the distributor because it's not cranking or turning over from what he says.........i would also try while turning the key to move your clutch pedal in and out, to see if it might be your clutch safety switch
Old Jan 26, 2005 | 02:07 PM
93_cxEG's Avatar
Default Re: HELP!!NO START!! (hybridem1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridem1 &raquo;</TD></TR><TR><TD CLASS="quote">i don't think it would be the distributor because it's not cranking or turning over from what he says.........i would also try while turning the key to move your clutch pedal in and out, to see if it might be your clutch safety switch</TD></TR></TABLE>
true...i agree...but one of my cousin have a similar situation and it was the rotor inside of the distributor.....so either take my advise or not...
Old Jan 26, 2005 | 02:10 PM
Mach69's Avatar
Before you do anything more that will cost you money, do this. If you have a manual transmission, there is a connector under the clutch that tells it the clutch is engaged. Connect those 2 wires together. This happened to me exactly what you stated. I did what I just told you to do and my car started right up. If you don't have a manual transmission or that didn't solve your problem, it most likely is the main relay, but there is a SMALL chance its the ignition.
Old Jan 26, 2005 | 02:17 PM
HatchBox's Avatar
Skoobie no more...
Default Re: HELP!!NO START!! (Mach69)
could be the starter relay aswell..
Old Jan 26, 2005 | 06:25 PM
Default Re: HELP!!NO START!! (HatchBox)
thanks for all the input, but here is some more info. it is a automatic to manual swap so i have no clutch safety switch and always started great before. and also i did double check the switch from the auto to make sure it is in the park position to start it. and it wouldnt be the distributor, this is because the distributor has nothing to do with the starter not cranking, because even if there was no distributor it would still crank. I have also checked all the fuses and they are all good. the only thing i have been able to come up with is that i have a open in the ignition to starter circut so when i get up tomorrow im gunna check all of that. but i appreciate all of the input. thanks.
Old Jan 26, 2005 | 06:30 PM
HatchBox's Avatar
Skoobie no more...
is the starter getting power at all?
Old Jan 26, 2005 | 06:32 PM
yeah i double checked the battery to starter hookup already and its good.
Jmx305
12
Dec 9, 2013 03:20 AM
Efhatch277
Feb 2, 2012 01:12 AM
IGuess
Nov 1, 2009 07:41 PM
curiousgpnoy
Jun 25, 2003 08:43 AM
Chuji
Jan 8, 2002 04:58 PM
