**Which cam gears**
Old Jan 26, 2005 | 01:17 PM
...emu...'s Avatar
Default **Which cam gears**
I will be running a Drag turbo kit at 8 and 5 psi. My motors is completly stock (b16a2). Which cam gears would you guys recommend? (most power) Thanks
Old Jan 26, 2005 | 01:20 PM
Hawkze_2.3's Avatar
Default Re: **Which cam gears** (milanoturbosi)
Doesn't ******* matter except for possible slippage on lower quality gears.
Old Jan 26, 2005 | 01:23 PM
ian.'s Avatar
Default Re: **Which cam gears** (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't ******* matter except for possible slippage on lower quality gears.</TD></TR></TABLE>
Old Jan 26, 2005 | 01:24 PM
Padawan's Avatar
Darth ModerVader
All cam gears will provide the same gains (don't bother with them if you don't plan on having them properly tuned), so you should base your choice on design, quality, and price. The only brand I would use or recommend is ST Corsa, mainly because they can't slip, but also because they are high-quality and reasonably priced.
Old Jan 26, 2005 | 01:25 PM
...emu...'s Avatar
Thanks for the input and I do actually plan to do dyno tuning
rdssk8rcs1
Nov 20, 2007 08:29 AM
ej1252
Nov 10, 2007 04:26 PM
1sikhatch
Nov 11, 2006 02:18 PM
f22abuilder
Feb 16, 2006 06:10 AM
ironchef25
22
Feb 12, 2004 12:05 PM
