welder shuts off power
Old Jan 26, 2005 | 12:13 PM
94b18c1's Avatar
Default welder shuts off power
everytime i try to weld the power shuts off and i have to go to the fuse box, what is everyone else doing to prevent this.
Old Jan 26, 2005 | 12:22 PM
Goullish's Avatar
Default Re: welder shuts off power (94b18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94b18c1 &raquo;</TD></TR><TR><TD CLASS="quote">what is everyone else doing to prevent this.</TD></TR></TABLE>
Using electric systems that can handle the load.
Sorry, couldn't help myself.
Old Jan 26, 2005 | 12:27 PM
RCautoworks's Avatar
Default Re: welder shuts off power (Goullish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goullish &raquo;</TD></TR><TR><TD CLASS="quote">
Sorry, couldn't help myself.</TD></TR></TABLE>
That is the only solution, does your power shut off as soon as you weld or when you get the stuck ? If you weld in my garage and you get it stuck to the metal and just hold the trigger the fuse will break.
Old Jan 26, 2005 | 12:46 PM
VRD^don's Avatar
Default Re: welder shuts off power (90blackcrx)
that happens to me only when i turn the amperage up..what do have your machine setup at?
Old Jan 26, 2005 | 03:36 PM
fulldragcrx's Avatar
Default Re: welder shuts off power (boosted_crx)
What Machine are you using and what is the amp rating of the breaker the machine hooked to?
Old Jan 26, 2005 | 08:41 PM
MR5sARECOOL's Avatar
Default Re: welder shuts off power (fulldragcrx)
You need to have your garage wired to handle the load. A new circuit should be installed with a higher amp breaker, along with the proper gauge wiring to accomodate this. If your welder is capable of 220v id use that if you can run a 220v circuit where you live. Its much much better.
<U> DO NOT</U> just go and replace the breaker for that circuit with a higher amp breaker. It is very dangerous and many houses burn down that way.
Also, you should find out what is hooked up to that circuit and turn those things off while welding (extra lights, refrigerators, radios, tv's, freezers, etc.)
If you have a shitload of other stuff hooked up to that circuit, try temporarly unplugging it until after you are done welding. If it still goes off, then upgrade the circuit.
Old Jan 27, 2005 | 02:42 PM
94b18c1's Avatar
YA IT HAPPENES WHEN THE ROD GETS STUCK, BUT I CANT EVEN PUT DOWN A BEAD TO GET IT STARTED, USUALLY WHEN IT GETS STUCK THERE ISNT ENOUGHT POWER RIGHT?
Old Jan 27, 2005 | 02:51 PM
Default Re: (94b18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94b18c1 &raquo;</TD></TR><TR><TD CLASS="quote">YA IT HAPPENES WHEN THE ROD GETS STUCK, BUT I CANT EVEN PUT DOWN A BEAD TO GET IT STARTED, USUALLY WHEN IT GETS STUCK THERE ISNT ENOUGHT POWER RIGHT?</TD></TR></TABLE>
It gets stuck because your going to slow or your holding it to close or the wire speed could be to slow. Thats what I think atleast.
Old Jan 28, 2005 | 10:57 PM
sohcvtec66
Guest
Posts: n/a
Default Re: (90blackcrx)
maybe a bigger gauge or size extrension cord?
Old Jan 31, 2005 | 10:46 AM
94b18c1's Avatar
Default Re: (sohcvtec66)
would that hinder that power that much? to make it shut off
Old Jan 31, 2005 | 01:39 PM
mopar junkie's Avatar
You are flowing more amps through the circuit than its designed to handle. You need to have an electrician install a new circuit that can handler more amperage. I use a 50A breaker and 8 gauge wire for my TIG welder. Works pretty good so far...
Old Feb 7, 2005 | 09:48 AM
94b18c1's Avatar
thanks
97CWITR
Feb 24, 2008 04:11 PM
illmatic520
Jan 23, 2008 07:21 PM
RsxType-Stitch
16
Sep 7, 2005 07:52 PM
Mugen_DC2R
Apr 20, 2004 03:58 AM
Brett
Jun 30, 2003 10:39 AM
