crvtec problems
Hey there, newbie here... just did a crvtec swap on my 93 EJ. Ok I have quadruple checked my timing and everythings good, plugs are right firing order and all my wiring is legit, but when my car revs to about 3500-4000 it boggs out, similar to rev limiter but more duration revs, and my car backfires hella when i let off. The ecu is throwing only one code and its not any of the 2 vtec codes or firing order code 4, just the auto tranny code *19 (because i got an auto ecu [which still revs out to 7200]) Can anyone help me out?
sounds like your auto ecu is trippin b/c it doesnt see the auto tranny sensors. convert your ECU to manual (there are how-tos on this site, just search) and get back to us
True, you would think that the auto ecu would play a big factor in it but This b16 swap I got from another car and before It ran fine, pulled hella and had a check engine light also so idk. I talked to hasport and they said it might be the dizzy so Ill try to figure that out.
lococoin
Jan 31, 2005 12:15 PM
