working on tranny...how do I hold down flywheel
I need to know how to hold down the flywheel so I can take out the star 17 socket...I dont know how I did it last time but I didnt need that much force but now I do...and the flywheel spins
learned this from a friend
-screw in a tranny bolt inside one of the lower tranny mounting holes
-stick a small bolt inside one of the flywheel holes
-get a wrench with a open end and stick it on the tranny bolt...turn the flywheel till the wrench hits the small bolt on the flywheel
hope i explained it ok
good luck...or just buy a compressor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DasaEJ1 »</TD></TR><TR><TD CLASS="quote">It wont mess up my teeth??</TD></TR></TABLE>
to answer your question, no, it will not mess up the teeth on the ring gear.
I found an easier way...just hold down the camgear...I gave up tho...cause It was freaken to tight...I used a breakerbar too and plus it was getting late so yeah...well thx guyz
