Which manifold?
Old Jan 25, 2005 | 08:55 PM
Maxboost00's Avatar
Default Which manifold?
For the R motor which manifold between the Blox and AEBS would you guys go with and why?
Old Jan 25, 2005 | 09:00 PM
white rocket's Avatar
Default Re: Which manifold? (Maxboost00)
Haven't heard any reviews on the Blox but it looks just like the Skunk2 which is basically a Type R mani anyway. The AEBS, however, has had a good response(searching for "AEBS" using the 'search' function will net some info) and those who have it seem to like it for the money. I've also read that the reversed vacuum lines have caused a bit of grief for install; whether it makes any difference when installed, I'm not sure.
<---who is contemplating the AEBS and a Hondata IM gasket.........hmmmmm
Old Jan 27, 2005 | 06:31 PM
StorminMatt's Avatar
Default Re: Which manifold? (white rocket)
On the other hand, I have also heard that any HP gains with the AEBS over the P73 are small at best and questionable at worst. Basically, this manifold seems to be a good way to go if you are upgrading from a stock B16A manifold. But it is not really a good improvement for the money if you are already starting with a P73.
Red_ED8
Jan 14, 2006 11:47 PM
92hatchattack
42
Sep 17, 2005 11:10 PM
nebulight
Nov 13, 2004 01:44 PM
2.2L EH2
Aug 1, 2002 12:03 PM
