fan not turning on
so my fan is not turning on, I tested the fan and the fuse and they are good. I still need to check the relay and ...
not sure what else to check just wondering what to check and how to test it
thanks guys
thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 »</TD></TR><TR><TD CLASS="quote">How did you test the fan?
unplugged it and put 12volts to it
Check or Replace the switch</TD></TR></TABLE>
where is the switch
where is the switch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benjithx »</TD></TR><TR><TD CLASS="quote">
where is the switch</TD></TR></TABLE>
its on the thermostat housing. unplug it and connect the 2 leads in the plug. your fan should then turn on (if your ignition is in the position II (on). if it does, then ur switch is bad.
my car takes forever for the fan to kick in, but it never over heats
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">
my car takes forever for the fan to kick in, but it never over heats</TD></TR></TABLE>
Thanks i will try asap
Does anyone here run there fan all the time to cut down underhood temps? When i bought my turbonetics kit there instructions showed a wire in the fuse box that made the fan run whenever the engine was on they said it was a good idea.
You can do that to cut back on excessive heat, but unless your having an overheating problem or expect to theres no real benefit. You might try getting a lower temperature switch so that it comes on sooner, or wire the relay to a switch inside the car so that you can turn it on at your discretion.
jump the switch
jump the switch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr_eg »</TD></TR><TR><TD CLASS="quote">
jump the switch</TD></TR></TABLE>
jump the switch</TD></TR></TABLE>???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benjithx »</TD></TR><TR><TD CLASS="quote">???
loop the female connection from the plug on the thermostat, the bronze thing under the intake manifold.....only problem is itll always run : P
Modified by itr_eg at 7:00 PM 1/26/2005
</TD></TR></TABLE>loop the female connection from the plug on the thermostat, the bronze thing under the intake manifold.....only problem is itll always run : P
i have never seen my fan turn on but i assume it works because my engine never overheats. I would check the fuses, but as long as your engine isn't overheating i don't think it is a major problem.
Eglifestyle
10
Mar 23, 2008 12:08 PM
lrcrx90
10
Apr 10, 2007 01:44 PM
