mn cleaning out garage lots os parts fs/ft
All parts are for sale so make me any offer as no decent offer will be denied
OBD0 PR4 ECU (90-91 LS ECU)
50 watt Honda speakers (2)
Haltech A/F & Injector Pulse Rate Gauge
PR3 A/C Bracket (2) (DA, DB, EF or EH)
B16 Headbolts
PR3 Power steering Pump and brackets (90-93 Integra)
B16 Flywheel with Pilot Bearing
b16 Pressure Plate (2)
GSR stock Clutch disk
1997 GSR Bare Head (needs work)
2001 GSR Short Block (needs new sleeves)
GSR Various Short Block Parts (main caps, 3 rods and pistons, oil pump, oil pickup, crank, rear main seal)
GSR Various Head Components (rocker shafts, rosker arms, lost motion assemblies, all sensors, waterneck)
Sony Xplod CD Player (50w X 4 with detachable face and wiring harness for DA)
OBD1 & OBD2 Injector clips
Endless Front Brake pads (96-00 civic or 92-96 Prelude)
99-00 Civic SI Rear Bracket
92-00 Civic or 94-01 Integra shift boot
00 GSR Proportioning Valve
B-Series AASCO 8 LB Flywheel with new pilot bearing
99-00 Civic SI Drivers Side Bracket
B-series OBD1 Drivers Side Mount
92 Civic A/C Bracket and Mount
GSR Upper Radiator Hose
OBD0 MSD Ignition Cap
OBD1 GSR Intake Manifold with all sensors
GSR Header with Heat Shield
94-97 GSR Power Steering Pump
OBD1 B16 Starter
obd1 b16 Intermediate Shaft
DA Drivers side Mount (2)
PCV Box, Hoses and valve for b-series
GSR Throttle Cable
DTM Dual Slash tip Cut Muffler (Universal)
92-95 Civic Corner Lenses
GSR Cams and camgears
GSR Stock intake
92 CIVIC CX Master Cylinder and Resevoir
GSR Oil Pan
Type-R Catylitc Converter
1996 Civic EX Seats and sliders
17 inch Eagle Alloys 5 star DEsign with Nankang Tires (5 Bolt)
92 civic Steering wheel with SRS (Airbag)
Call me at 952-201-6063 and ask for Jon if interested in anything here or just IM ME, Thanks everyone for looking
Modified by dategb16vortech at 8:37 AM 2/18/2005
Modified by dategb16vortech at 12:34 PM 2/27/2005
B16 Headbolts
OBD1 B16 Starter
GSR Throttle Cable
GSR Stock intake
GSR Oil Pan
how much for the gsr crank? has it ever spun a bearing?
how much for the gsr oil pan? is it stock? has it been tapped for turbo? i need a stock one.
2001 gsr crank $100 never spun bearing. Piston hit valve while spraying N20 100 shot slleves were cracked and piston 1 fried along with head but no crank damage. Oil Pan is stock from the same motor and has been thouroughly cleaned but was never used for turbo. Stock pan 50 obo
got model # of sony cd player it is a cdx-c5000-x and it is sony xplod 50wx4. I have pics but I don't have your email to send them to so IM me your email address
thought I would give an updated list of my stuff
B16 Headbolts
JDM Gears Oil Catch Can (Mint)
92-00 Civic or 94-01 Integra shift boot or Type-R Knockoff Boot
OBD1 B16 Starter
GSR Throttle Cable
GSR VAlvecover (giving to You)
GSR Stock intake
GSR Oil Pan
17 inch White Motegi MR7 Wheels with Yokohoma Parada Tires
17 inch Eagle Alloys 5 star Design with Nankang Tires (5 Bolt)
I also will have in a week or 2 FREE 92 civic cx rear trailing arms with drum brakes and rear LCA's, NO SUSPENSION, but everything is FREE as I just want to get these out of my garage when I get my 2001 GSR rear brakes done. First come, first serve.
B16 Headbolts
OBD1 B16 Starter
GSR Throttle Cable
GSR Stock intake
GSR Oil Pan
hey how much for the headunit shipped to 78218 got pics?? x4g63trbox@hotmail.com
I wante dto get $100 for headunit as it is in good shape but I will take $110 for it and that covers shipping. you get deck harness adapter and mounting kit for 90-93 integra
