Best cutting tool for 10 ga sheet?
Old Jan 25, 2005 | 06:37 PM
Formula Racing's Avatar
Default Best cutting tool for 10 ga sheet?
Lookingtomake various plates and brackets/braces.
I dont feel the need to spend another $1000 and get a plasma cutter.. So what else works?
I have a jigsaw.. I suppose it should work...Any other ideas?
Old Jan 25, 2005 | 06:39 PM
Goullish's Avatar
Default Re: Best cutting tool for 10 ga sheet? (Formula Racing)
Sawzall, Fire blade.
Die grinder, carbide laced cutting wheel.
Angle grinder, cutting wheel (or grinding wheel even).
Old Jan 25, 2005 | 08:34 PM
Engloid's Avatar
OG Fabricator
Default Re: Best cutting tool for 10 ga sheet? (Goullish)
If you mark it up or can make a sketch, you may find a local shop to shear it pretty cheaply...as the labor time is all that you'd be paying for.
Old Jan 25, 2005 | 10:43 PM
Goullish's Avatar
Default Re: Best cutting tool for 10 ga sheet? (Engloid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Engloid &raquo;</TD></TR><TR><TD CLASS="quote">If you mark it up or can make a sketch, you may find a local shop to shear it pretty cheaply...as the labor time is all that you'd be paying for. </TD></TR></TABLE>
Yeah, you could also have them break bend any thing you need at the same time, and won't have to resort to the old vice+hammer way of doing things.
NA425DragSter
Northwest
Jun 16, 2008 01:09 PM
eskerley
Feb 14, 2008 03:24 PM
Terrible One
Jun 1, 2006 09:14 PM
George Knighton
Aug 30, 2005 07:48 AM
manveer
Apr 18, 2003 10:14 AM
