Virgin P28 with obd2 B18C1..... engine light? *VIDEO*
Old Jan 25, 2005 | 06:11 PM
lazynok's Avatar
Default Virgin P28 with obd2 B18C1..... engine light? *VIDEO*
would this naturally produce a cel?
NO wiring has been done what so ever on the vehicle.. just plugged right in. B18C5EH3 says this will work and the harnesses are backwards compatible,.. since P28 isnt seraching for a knock sensor, crank angle sensor, or IABs... it should run normally, correct?
NOTE: i cannot check this cel. Every other cel that I have had on this engine, I was able to check the code. This does NOT flash or anything when I jump the harness. Thats why it's so perplexing.
What happens is, I turn the car on, it goes high up in the rpms, then dips down to 100-300 rpm and feels like its going to die, then stabilizes at ~700 rpm. When it stablizes I get a check engine light. This light is, I guess, making me run in limp mode... cause when I WOT my new engine... nothing relaly happens. Is this normal with a P28 and an obd2 gsr?
http://www.nok7.com/light.avi *video of my cluster to see wtf is going on*
please don't respond with "check the code"... like I said... its not telling me a code. I had three codes when I first got this engine working.. but I fixed those so I know my ecu isnt bad and thats why it's doing this.. it must be something else...
thanks in advance
Old Jan 25, 2005 | 07:14 PM
dms-100's Avatar
Default Re: Virgin P28 with obd2 B18C1..... engine light? *VIDEO* (lazynok)
got to <3 nok but I = have no idea -)
Old Jan 25, 2005 | 09:49 PM
Andres-eh2's Avatar
How's the timing and MAP sensor?
iluvmyEJ1
May 20, 2007 06:01 PM
Mario.
Apr 27, 2006 09:32 AM
valentino2k3
Oct 8, 2004 01:08 PM
lilxvtecxpwr
Jun 24, 2002 03:59 AM
