what main caps do I use in a frankenstein motor
Old Jan 25, 2005 | 06:05 PM
ebrakeracin4's Avatar
Default what main caps do I use in a frankenstein motor
I am building a gsr block with ls crank, what main caps do I use, The ones from the gsr block or the ls that go with the crank.
Old Jan 25, 2005 | 08:55 PM
cheesebug's Avatar
Default Re: what main caps do I use in a frankenstein motor (ebrakeracin4)
How's that working out for you since the gsr and the ls crank main journels are two different diameters?
Old Jan 25, 2005 | 10:03 PM
Default Re: what main caps do I use in a frankenstein motor (cheesebug)
HUH?
Old Jan 25, 2005 | 10:13 PM
mmuller's Avatar
Mad Scientist
the mains are the same.
you use everything from your gsr block.
Old Jan 26, 2005 | 02:15 PM
Default Re: what main caps do I use in a frankenstein motor (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">the mains are the same.
you use everything from your gsr block.</TD></TR></TABLE> thanks.
acura_b18c1
May 11, 2011 12:46 PM
ferio 95
Oct 7, 2004 08:58 AM
Aphrodavid
May 20, 2003 07:17 PM
MTP04
Jan 2, 2003 04:30 PM
