Weird Noises after MSD ignition components install? Opinions ?
Old Jan 13, 2002 | 03:58 PM
LshatchTurbo's Avatar
New User
Default Weird Noises after MSD ignition components install? Opinions ?
I just installed a MSD 6AL, Blaster SS coil, modified distributer cap, and bosch double platinum plugs. Sometimes when I am driving I here a sort of "cluck cluck" noise coming from the front of the car. When I stop and open the hood there is a weird electrical smell, not burning though. Could this because I havent installed my new spark plug wires yet (not here yet)? Is this a issue maybe with timing? Am I frying my altenator with all the MSD components. This is a LS EG6. It had over 80k on it so i went ahead and swapped a bunch of stuff. Any opinions would be appreciated. Thanks!
Old Jan 13, 2002 | 04:05 PM
94gsr's Avatar
Default Re: Weird Noises after MSD ignition components install? Opinions ? (Zynentech)
I have no idea what to tell you about the noise, but I'd say that the smell is you frying your wires. You shouldn't have put all that **** in without some good aftermarket wires. If you have to drive it, I'd take it easy on the car until your wires come.
Old Jan 13, 2002 | 06:46 PM
New User
Default Re: Weird Noises after MSD ignition components install? Opinions ? (94gsr)
hmm could it be that I am using platinum plugs. I heard platinum plugs heats up like **** without ignition upgrade. Could I be getting jumps using that? Should I try copper plugs?
Old Jan 14, 2002 | 04:16 AM
Mista Bone's Avatar
D Tranny Guru
WHat size wire did you use for power to the MSD box???
Never a weird smell or noise hear.
Old Jan 14, 2002 | 07:22 AM
New User
Default Re: Weird Noises after MSD ignition components install? Opinions ? (Mista Bone)
I used the power wires supplied with the 6AL.
Old Jan 15, 2002 | 07:53 PM
DIZASTICAL's Avatar
are you sure that the wires going into your dis. cap are not hitting the rotor botton as it spins in the dis. ??????????
ProjectEvilEj2
Feb 6, 2013 05:08 AM
SOHC SPEED
Jul 20, 2008 06:45 PM
Cpt Ben
Apr 18, 2006 10:21 PM
cdk001
Mar 30, 2006 09:57 PM
StageIIIhb98
Dec 17, 2002 05:58 PM
