WTB: OBD0 and OBD1 distributor plugs for OBD0 to 1 conversion
I'm putting a B16 head on my '91 integra and converting it to OBD1. I need the OBD0 distributor plugs that are on the distributor, and also OBD1 distributor plugs that will plug into my B16 OBD1 distributor
Please PM if you can help me out, thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8 »</TD></TR><TR><TD CLASS="quote">I'm putting a B16 head on my '91 integra and converting it to OBD1. I need the OBD0 distributor plugs that are on the distributor, and also OBD1 distributor plugs that will plug into my B16 OBD1 distributor
Im confused are you sure can covert a obd0 distributor to obd1 by changing clips. If you are converting the obd0 distributor to obd1 just use the stock obd0 engine harness and buy a obd0- obd1 coversion harness for the ecu. Thats how i think you could do it.
</TD></TR></TABLE>Im confused are you sure can covert a obd0 distributor to obd1 by changing clips. If you are converting the obd0 distributor to obd1 just use the stock obd0 engine harness and buy a obd0- obd1 coversion harness for the ecu. Thats how i think you could do it.
No, you cant run an OBD0 distributor with an OBD1 ECU
I am saying I dont want to hack up my wiring harness. I want to make an adapter harness to use an OBD1 distributor on a car wired for an OBD0 distributor
confused yet?
confused yet?
viking-101
10
Feb 22, 2012 01:46 PM
sirtef9
Sep 13, 2009 05:33 PM
