89 accord LX
Old Jan 25, 2005 | 02:27 PM
89_honda_accord's Avatar
Default 89 accord LX
headlights doors won't open what could be possiable causes? it is the switch or or relay not sure where relay is to check it.
Old Jan 25, 2005 | 09:19 PM
Vanilla Sky's Avatar
relay, fuse, controller, wiring, the motors themselves... that's all the possible causes... the relay is on the back of the underdash fuse panel, the controller is under the dash, it's marked "retractable headlight controller" or something to that effect, and i believe there are fuses for it both in the engine bay and under the dash... check those out...
also, do they open with the switch in the 3 switch cluster to the right of your steering wheel?
if you can't get them up electrically, you can take the caps off of the motor tops and turn the ***** and manually put the lights up until you can get the mechanism fixed
http://www.3geez.com is a much better resource for third gen accords than HT
JTR
Jan 11, 2015 04:33 AM
Dave1821
Apr 18, 2009 01:48 PM
Jmunk
Dec 18, 2006 08:47 AM
92wraith
Oct 12, 2005 06:31 PM
1slowcrx
May 17, 2005 04:37 PM
