Cams?
Old Jan 25, 2005 | 01:33 PM
mod88's Avatar
Default Cams?
where can i find a cam for 1988 civic 1.5l cant find anywhere near here some one help plz??
Old Jan 25, 2005 | 01:52 PM
ServiceAdvisor's Avatar
For what reason? lol, for the price your gonna pay for an aftermarket cam, you could swap in an entire d16a6(88-91Civic/CRX Si motor) and atleast have some kind of ground for making *power*. - Darrell
Old Jan 25, 2005 | 01:55 PM
mod88's Avatar
Default Re: (DOHCZCCRXSi)
i already have 140hp just porting everything would like more
Old Jan 25, 2005 | 01:57 PM
mod88's Avatar
Default Re: (mod88)
cold air , header, cat back exhaust, pistons, rods, higher lift, and a blower
Old Jan 25, 2005 | 01:59 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Cams? (mod88)
The head is the same casting as the A6.
any A6 cam will fit in there perfectly.
While you are at it, pick up an A6 manifold (or one from a Y8), Si distributor, resistor box, and an Si ECU and take advantage of the benefits MPFI can give you. Allt hat for about $75 and it will really set that blower and cam off correctly.
Old Jan 25, 2005 | 02:06 PM
mod88's Avatar
Default Re: Cams? (4drEF)
thanks man,, you think that cam will help the blower a lot its off a super coupe, i had to mod everthing to fit right,, moved the alternator where my old ac was and put the blower at the back of the motor and got a extra cold start injector of a old vw and a pressure switch and set it to 12 psi..think it will go??
Old Jan 25, 2005 | 02:42 PM
4drEF's Avatar
Keyboard Humorist
Will a cam help?
YES!
Locate a nice cam with a turbo grind on it.
Seriously look into converting to MPFI.
I don't know of any ECU chips or mods for the DPFI ECU.
With a PM6 (the Si ECU) you can chip it and run something like Turboedit to control your fuel and ignition needs for boost.
Old Jan 25, 2005 | 02:47 PM
mod88's Avatar
where could i find some of this?? anywhere i dont care i have money to spend??
Old Jan 25, 2005 | 02:58 PM
4drEF's Avatar
Keyboard Humorist
Try contacting http://exospeed.com/ for a turbo cam.
If they don't have one for you, then I would give http://jgenginedynamics.com/ a call. They have a decent turbo cam.
Turboedit is free.
Take a look at http://www.turboedit.org/.
You will need to have a chipped ECU or chip it youself if you have the know-how.
Take a look at the Turboedit forum on http://pgmfi.org/ for more detailed info.
If money is no object, then you could convert to OBD-1 and run a http://hondata.com/ ECU or some other mainstream ECU/standalone like an AEM EMS (http://www.aempower.com/product_ems.asp).
Old Jan 25, 2005 | 03:04 PM
mod88's Avatar
thanks buddy if i need anymore help ill come to you.. have a good one
Old Jan 25, 2005 | 03:07 PM
4drEF's Avatar
Keyboard Humorist
Take a pic of that Super Coupe blower for us!
That sounds like some cheap easy boooooooooooost!
Old Jan 25, 2005 | 04:01 PM
mod88's Avatar
Yeah my digitals getting fixed ill take pics of what i used and how i made the brakets
Fo-Do Fanatic
Oct 5, 2011 02:49 AM
Sheep
29
Apr 2, 2007 11:01 PM
95DX_D15B
May 11, 2006 02:07 PM
hondacivic4g
Aug 12, 2003 04:27 AM
pornstarSR
Oct 11, 2002 02:55 PM
