y8 head on d15b2 block
Old Jan 25, 2005 | 01:09 PM
mengy007's Avatar
Default y8 head on d15b2 block
the head on my 91 4door is messed up. I have a y8 head sitting at home, I was wondering if I could put that on, use the old b2 IM so i wouldn't have to switch to MPFI and rewire the dizzy plugs?
Old Jan 25, 2005 | 01:11 PM
CRX_Control's Avatar
Default Re: y8 head on d15b2 block (mengy007)
you know the y8 head is vtec right. so do the obd1 and get a obd1 dizzy and conversion harness and hook up vtec.
Old Jan 25, 2005 | 01:21 PM
mengy007's Avatar
Default Re: y8 head on d15b2 block (CRX_Control)
well yes because it came off my mini-me setup (d15b7 block / y8 head)
the y8 head is obd-II and I have both obd-1 and odb-2 dizzy although I used the obd-1 dizzy with my mini-me and it worked fine... so i should just convert to obd-1 and use an obd1 harness with ecu?
Old Jan 25, 2005 | 02:32 PM
obd1 conversion harness(jk conversion harness), obd1 dizzy,obd1 ecu (perferrably the p28) , mpfi manifold like the y8 manifold is just fine, use obd1 or 2 for injectors without the resistor box(solder the 4 wires). dont forget to remove the oil jet from the block of the d15b2 .and a 4 wire o2 sensor
Modified by CRX_Control at 7:52 PM 1/25/2005
Old Jan 25, 2005 | 02:34 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">obd1 conversion harness(jk conversion harness), obd1 dizzy,obd1 ecu (perferrably the p28) , mpfi manifold like the y8 manifold is just fine, use obd1 or 2 for injectors without the resistor box(solder the 4 wires). dont forget to remove the oil jet from the block of the d15b2 .</TD></TR></TABLE>
...and a 4 wire O2.
Old Jan 25, 2005 | 02:43 PM
Default Re: y8 head on d15b2 block (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">...and a 4 wire O2.</TD></TR></TABLE> ahh ! you didnt let me finish my sentence
Old Jan 25, 2005 | 02:46 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote"> ahh ! you didnt let me finish my sentence </TD></TR></TABLE>
Oh... I'm sorry.
Go ahead then.
JAYSCRX420
Nov 30, 2018 06:21 AM
viskii420
17
Oct 29, 2006 09:01 AM
vegaskurt
May 14, 2005 10:17 PM
hatchback_al
Sep 27, 2004 11:31 AM
slocrxsi
Nov 18, 2003 05:17 AM
