removing engine need help
ok i disconnected the wires, hoses, lines and everyting i need(hopefully). but how do i take the axel out of the tranny without removing the bitch bolt? or do i HAVE to take the cent nut off? please help asap cause im almost done
You need to remove the large (32mm) axle nut. Then you need to separate the lower balljoint. Then remove the shock fork and swing the hub away from the axle and voila remove the axle from the trans. All of these processes are detailed in the honda shop manual.
serious
Jun 8, 2002 11:23 AM
