tach question
Old Jan 25, 2005 | 11:14 AM
tcwcrxhf's Avatar
Default tach question
What would cause my in dash tach to say 0 and my Auto-meter tach to read normal idle speed?
1. My in-dash tach revs witht the engine but is horribly inaccurate
2. Everything else on the dash works perfectly
3. The engine is running when i made these observations
4. 91 CRX HF with si motor and tranny and 90 pm6 ecu
It just started happening today so any advice would be great but the car as a whole seems to run normally
Old Jan 25, 2005 | 11:23 AM
MONSTERZC's Avatar
Default Re: tach question (tcwcrxhf)
did u get your tach signal wire from behind the cluster. if so disconnect the wire for the autometer and run it to the blue wire on the dizzy plug its a 2 wire plug. i had the same problem thats how i fixed mine
Old Jan 25, 2005 | 02:46 PM
tcwcrxhf's Avatar
Default Re: tach question (MONSTERZC)
mines hooked to the blue wire at the dizzy remember this is the in dash tach not working right and the auto meter works fine
Old Jan 25, 2005 | 05:37 PM
black90si's Avatar
If you have an autometer why are you worried about the tach in the dash?
Mikey3000
Sep 6, 2006 02:32 PM
C_R_X_V_T_E_C
Jul 2, 2006 03:16 PM
Hatch'd
Apr 19, 2005 09:49 AM
91glassycrx
Apr 6, 2004 03:59 AM
element_1one
Jun 16, 2003 08:50 PM
