Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Custom THREADED Vaccum Line Kit starting at $ 16 shipped. IN Gangsta BLACK !!
Old Jan 25, 2005 | 10:54 AM
Flamenco-T's Avatar
Default Custom THREADED Vaccum Line Kit starting at $ 16 shipped. IN Gangsta BLACK !!
Introducing the New Fast-Turbo.com Vaccumm Line kit. The Easiest, Simplest and Safest way to run Vaccumm Signal from your Compressor Housing to your Wastegate.
The kit consist of:
2 - feet of the 1/4" Polyurethane Felxi Line in Black.
1- 90 Degree Connector for the Wastegate, SWIVEL !!!!
1- Straight Connector for the Compressor Housing.
The line are so easy to install, it will takes literraly 2 seconds to assemble the line to the hose ends.
This setup will allows you run to a Push-Lock line from side port of your Wastegate to the compressor housing. If you compressor housing does not have the hole, you can easily take it off, drill it and tap it to 1/8" NPT.
Installed Pics
and
Can also be installed on FPR, Blow off Valve, Boost Controller and solenoids, Boost Gauge, Vaccum Manifold and etc. If it has a threaded port, it can be done.
Sample pics of Fuel Pressure Regulator
Compatibility:
Anything that has a threaded ports of 1/8 NPT. It can only transfer Vaccum, no fluid or fuel.
<FONT COLOR="red">Pricing: $ 16 shipped</FONT>
To upgrade the Straight Hose ends to 90 degree, pelase add $ 1.00
<FONT COLOR="blue">Ordering Info :</FONT>
Phone: 888-887-2658
E-mail: stan@fast-turbo.com
Ordering via Paypal:
For the standard kit as shown above:
Standard Kit
For the 2- 90 degree hose ends kit:
CMZ2
We accept:
Paypal - <FONT COLOR="green"> paypal@fast-turbo.com</FONT>
Credit cards
Check
Money order
Cash
Blood
If you need aditional hose ends and hose to make your own custom vaccum line kit, give me a call or IM me.
thanks again guys,
Stan
Modified by Flamenco-T at 10:20 AM 5/5/2005
Old Jan 25, 2005 | 11:08 AM
FOrSfEd's Avatar
Default Re: Custom THREADED Vaccum Line Kit starting at $ 16 shipped. IN Gangsta BLACK !! (Flamenco-T)
up for Stan
Old Jan 25, 2005 | 12:04 PM
h22 civic's Avatar
Default Re: Custom THREADED Vaccum Line Kit starting at $ 16 shipped. IN Gangsta BLACK !! (FOrSfEd)
r u sure those aint your hands???
Old Jan 25, 2005 | 12:49 PM
Flamenco-T's Avatar
Default Re: Custom THREADED Vaccum Line Kit starting at $ 16 shipped. IN Gangsta BLACK !! (h22 civic)
hahah yeah, I promise
Stan
Old Jan 25, 2005 | 04:15 PM
93hatched_projekt's Avatar
pm sent!
Old Jan 28, 2005 | 10:49 AM
integlspwr2k's Avatar
Default Re: Custom THREADED Vaccum Line Kit starting at $ 16 shipped. IN Gangsta BLACK !! (93hatched_projek
nice french tip manicure STAN!!
Old Jan 28, 2005 | 08:52 PM
NVturbo's Avatar
O.G. triple O.G.
Hey Stan...I am pretty sure these lines are leak-free..right? It looks very good by the way...I might end up getting a kit.
Old Jan 29, 2005 | 06:34 AM
Laserjock's Avatar
Default Re: Custom THREADED Vaccum Line Kit starting at $ 16 shipped. IN Gangsta BLACK !! (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote">Hey Stan...I am pretty sure these lines are leak-free..right? It looks very good by the way...I might end up getting a kit. </TD></TR></TABLE>
i've used these fittings and lines in 4500 psi applications, but I have no experience with them under vaccum let's say 20-30 in/HG. The push lock connectors are designed to lock under pressure. They'll hold high pressure fine at 16 ***** per second in my timmy!
<FONT SIZE="5">These lines can handle 1000 psi and maybe a bit more but not 4500 psi</FONT>
Modified by Laserjock at 1:31 PM 2/3/2005
Old Jan 29, 2005 | 11:37 AM
Sohc Driver's Avatar
Default Re: Custom THREADED Vaccum Line Kit starting at $ 16 shipped. IN Gangsta BLACK !! (Laserjock)
Stan! My sister is still complaining about the scratch marks on her back!! WTF DUDE!!??
Bump for Stan ,
Khoi
Old Jan 30, 2005 | 07:53 PM
Flamenco-T's Avatar
Default Re: Custom THREADED Vaccum Line Kit starting at $ 16 shipped. IN Gangsta BLACK !! (Sohc Driver)
Of course they are leak free
Laserjock, thank you....
Khoi: lol
Okay, if you guys insist, I can show the bigger picture the owner of those french manicure
stan
Old Feb 2, 2005 | 10:32 AM
Flamenco-T's Avatar
uppity
Old Feb 2, 2005 | 11:51 AM
Quad-Damag's Avatar
how much blood for the line?? for realz
Old Feb 2, 2005 | 01:20 PM
808 NA1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laserjock &raquo;</TD></TR><TR><TD CLASS="quote">
i've used these fittings and lines in 4500 psi applications, but I have no experience with them under vaccum let's say 20-30 in/HG. The push lock connectors are designed to lock under pressure. They'll hold high pressure fine at 16 ***** per second in my timmy!</TD></TR></TABLE>
They work for me at 20bps on my Angel haha.
Old Feb 2, 2005 | 01:49 PM
Danger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">
stan</TD></TR></TABLE>
so wheres the pic at ? bump for stan
Old Feb 2, 2005 | 03:20 PM
Arturbo's Avatar
Better than steak
25 Year Member
and
As seen on the Urban Legend. I use these and I know a lot of racers use them too that run 50psi of boost!! So they will not leak.
Stan the sneaky guy taking pics of my car..
Old Feb 3, 2005 | 09:05 AM
Guru Designs's Avatar
* B A N N E D *
buddy honestly. No tank will put out 4500psi nor i know of any marker that has an operating pressure of 4500 psi. At most in paintball, macro lines hold 1000 psi and thats only on adjustable tanks which i honestly dont think even go that high. On your timmy your running at most 650 psi into your regulator which is droped down to about 150-300 psi. No macro line is 4500 psi safe. i personally think that nothin out beats steal braided lines.
Old Feb 3, 2005 | 09:42 AM
Flamenco-T's Avatar
Default Re: Custom THREADED Vaccum Line Kit starting at $ 16 shipped. IN Gangsta BLACK !! (tobe2be)
I agree with you 100% that nothings beat a stainless braided line with teflon tube, but for a lower alternative option that can be removed easily, this is the way to go...
stan
Old Feb 3, 2005 | 10:39 AM
Diablo Tejano's Avatar
Up for Stan.
Old Feb 3, 2005 | 12:09 PM
NJIN BUILDR's Avatar
This looks like a great setup.I never liked rubber hose and zipties.
And a note on braided steel line.Unless its designated for vacuum it can collapse the inner teflon tube without collapsing the braid.The stuff desingned for pressure and boost has the inner bonded to the outer.
Glenn
Old Feb 3, 2005 | 12:30 PM
Laserjock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tobe2be &raquo;</TD></TR><TR><TD CLASS="quote">
buddy honestly. No tank will put out 4500psi nor i know of any marker that has an operating pressure of 4500 psi. At most in paintball, macro lines hold 1000 psi and thats only on adjustable tanks which i honestly dont think even go that high. On your timmy your running at most 650 psi into your regulator which is droped down to about 150-300 psi. No macro line is 4500 psi safe. i personally think that nothin out beats steal braided lines. </TD></TR></TABLE>
Yes, you are corret and I will edit my post above. These lines can handle 1000 psi and maybe a bit more but not 4500 psi like I said above.I typed that really late and was in a hurry. Is that a X/E-mag in your sig. And your handle looks familiar. Are you on AO? If so, imstoiched!
Old Feb 3, 2005 | 01:55 PM
allmotorhatch's Avatar
The new macro line out now is able to withstand around 1200psi. It is also more flexible then the old style. On an intimidator you want your reg prssure to be around 260 and your operating pressure around 80psi.
Old Feb 4, 2005 | 12:29 AM
Arturbo's Avatar
Better than steak
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">I agree with you 100% that nothings beat a stainless braided line with teflon tube, but for a lower alternative option that can be removed easily, this is the way to go...
whatever dude, SS lines are too heavy!
Old Feb 4, 2005 | 07:01 AM
Flamenco-T's Avatar
Default Re: Custom THREADED Vaccum Line Kit starting at $ 16 shipped. IN Gangsta BLACK !! (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">
whatever dude, SS lines are too heavy!</TD></TR></TABLE>
LOL
stan
Old Feb 6, 2005 | 02:12 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">Of course they are leak free
*starsky and hutch voice* Do it!
Old Feb 15, 2005 | 10:42 AM
Flamenco-T's Avatar
Default Re: Custom THREADED Vaccum Line Kit starting at $ 16 shipped. IN Gangsta BLACK !! (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">
hmmmmm
stan
