Downpipe Question
Old Jan 25, 2005 | 09:42 AM
s2k_al's Avatar
Default Downpipe Question
Im about to boost my 94ls that is in my 88 crx and im going to need a downpipe. What size downpipe should i go with 3in. or 2.5 in. and why. And where can i find a down pipe made for my setup, am i going to have to make my own. And does the piping have to be mandrel bent. thanks.
Old Jan 25, 2005 | 10:40 AM
96-EJ6 B18C's Avatar
Default Re: Downpipe Question (s2k_al)
I would reccomend using 3 inch mandrel piping if you can fit it. If not then go with 2.5 inch mandrel. The larger diameter allows the exhaust to flow out of the turbo easirer with less back pressure, which promotes faster spool up.
EDIT: You should be able to get the mandrel U-bends form summit or jegs for pretty cheap.
Old Jan 25, 2005 | 03:35 PM
s2k_al's Avatar
should i use mandrel bends for the fmic piping too.
Old Jan 25, 2005 | 11:43 PM
Default Re: (s2k_al)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2k_al &raquo;</TD></TR><TR><TD CLASS="quote">should i use mandrel bends for the fmic piping too.</TD></TR></TABLE>
Only way to go.
Old Jan 25, 2005 | 11:54 PM
MR5sARECOOL's Avatar
Default Re: (96-EJ6 B18C)
remember to get something suitable for extreme heat, thick stuff. Ive known many people who have had to reweld many times
GOOD LUCK
Old Jan 26, 2005 | 12:27 PM
Default Re: (MR5sARECOOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR5sARECOOL &raquo;</TD></TR><TR><TD CLASS="quote">remember to get something suitable for extreme heat, thick stuff. Ive known many people who have had to reweld many times
GOOD LUCK</TD></TR></TABLE>
Good point!
Old Jan 26, 2005 | 06:19 PM
s2k_al's Avatar
werd
Scheizty
Dec 4, 2007 05:46 AM
HS2G
Apr 13, 2005 10:15 PM
ThePro
Oct 26, 2004 11:12 AM
Fuzion
Sep 17, 2003 11:59 AM
Rory Breaker
Dec 11, 2002 10:43 AM
