Engine for my CRX
Old Jan 25, 2005 | 09:11 AM
1stcrxman's Avatar
Default Engine for my CRX
I need help. I am on a budget, but I want a good engine. I was thinking for low end I would go with the ZC dohc, but aftermarket oppurtunities or out there for that? Or my second choice, and probabley the wiser one, is to get the B16A 1st gen. If anyone knows of any aftermarket items that would bump the zc up to about 200 to 250 hp, please let me know. Thanks alot every body.
Old Jan 25, 2005 | 09:19 AM
EP3_05's Avatar
Default Re: Engine for my CRX (1stcrxman)
Turbocharging the ZC will get you to 250 and even higher if you build the bottom end and tune the engine correctly.
Old Jan 25, 2005 | 09:25 AM
1stcrxman's Avatar
Default Re: Engine for my CRX (91civic)
Do you know where I can get parts, i.e. cams, turbo kit, pistons, engine management, that kind of stuff for the zc??
Old Jan 25, 2005 | 09:41 AM
thirteen20CRXSi's Avatar
the turbo kit is the exact same as the d16
Old Jan 25, 2005 | 09:44 AM
1stcrxman's Avatar
Default Re: Engine for my CRX (thirthteen20CRXSi)
SO if I order parts for the engine, everything except cams will match up with the d16 engine?
Old Jan 25, 2005 | 09:59 AM
well cams and pistons are different well im not too sure about the pistons
Old Jan 25, 2005 | 10:01 AM
1stcrxman's Avatar
Any idea where I can get aftermarket parts??
Old Jan 25, 2005 | 04:23 PM
JRP bud good ****
make sure you get a clutch master clutch
Old Jan 25, 2005 | 04:45 PM
Rex Junkie's Avatar
i know HKS makes an old school kit for the ZC, i'm not positiive on the numbers though. If i had a ZC it's what i would do
Old Jan 25, 2005 | 06:21 PM
Default Re: Engine for my CRX (Rex Junkie)
do wat junkie says hks is real good
Old Jan 25, 2005 | 06:31 PM
Creepshow S60's Avatar
Allthough this is a question that's only been asked 4923$194783**3290;438 TIMES, i'm going to reply because i'm in a good mood (just received my GWAR dvd from ebay)
There's really a LOT of options if you're on a budget. I think the biggest question is how mechanically able you are to work on your car. Obviously if you're inexperienced and paying somebody to do the work, it'll be much more spendy.
If you're thinking of a "low budget motor" IE: ZC, SOHC VTEC...then boost is always a great power adder. If I were you, i'd consider a turbo kit.
There ARE aftermarket parts for the DOHC ZC as well. A common thing to say on this site is "ZC aftermarket sucks". Sure, there aren't nearly as many items for the ZC, but there's stuff out there. Besides, if you really want power, you'd boost it anyways...and boost is universal.
FYI, there's a guy in an 89 Civic sedan with a boosted ZC running consistant high 13's. He did the whole thing on a "budget". Just an example of what's possible for you.
JohnED7
Sep 5, 2014 04:09 AM
vti_shifter
Jul 17, 2005 08:31 AM
Dan Norton
15
Oct 16, 2003 07:17 AM
wicked2night
27
Jun 12, 2003 07:05 PM
