Will 94-98 RSR exhaust fit on a 00 GSR?
Old Jan 13, 2002 | 12:53 PM
Downey's Avatar
Default Will 94-98 RSR exhaust fit on a 00 GSR?
im buying another RSR for a friends 2000 GSR, but the guy said they only have applications for the 94-98 GSR. Someone said the 99-00 use a longer or shorter mid pipe. I have no idea. Will the 94-98 fit? Please help, i need to know ASAP!
Thanks
Graham
Old Jan 13, 2002 | 01:07 PM
civicdragon's Avatar
Default Re: Will 94-98 RSR exhaust fit on a 00 GSR? (Downeybear11)
the middle pipe, which is connected to the cat is 4 inches too long. have someone cut and reweld the pipe but make sure they cut it near the front.
Old Jan 13, 2002 | 01:37 PM
Big Teggie's Avatar
Default Re: Will 94-98 RSR exhaust fit on a 00 GSR? (civicdragon)
I had a 94-99 skunk2 exhuast on my car, it fit fine, the muffler only hung out like 4 inches too far. Its wasnt that bad, it depends on the kinda muffler.
[Modified by Big Teggie, 5:38 PM 1/13/2002]
Old Jan 13, 2002 | 02:33 PM
Rory Breaker's Avatar
Default Re: Will 94-98 RSR exhaust fit on a 00 GSR? (Big Teggie)
Yep, any muffler shop can slice it up and make it fit, no big deal. Shouldnt cost much at all!
Old Jan 13, 2002 | 03:05 PM
threatcon13's Avatar
New User
Default Re: Will 94-98 RSR exhaust fit on a 00 GSR? (newgsrdriver)
yea it wont bolt on directly..will have to get it modified.
Old Jan 13, 2002 | 03:11 PM
StinkyTofu's Avatar
Default Re: Will 94-98 RSR exhaust fit on a 00 GSR? (turbo01gsr)
if you swap out the cat with a '94-'98 cat it will fit correctly
Old Jan 13, 2002 | 04:48 PM
BlueG3Teg's Avatar
New User
Is it true that 94-2001 RS/LS exhaust are interchangeable as the 00+ GSR and 97+ ITR's?
Old Jan 13, 2002 | 07:40 PM
StinkyTofu's Avatar
Default Re: Will 94-98 RSR exhaust fit on a 00 GSR? (BlueG3Teg)
That is 100% true
Old Jan 13, 2002 | 10:31 PM
Downey's Avatar
what are the exact measurments?
1hotintegra
May 16, 2003 09:22 AM
CROM
Mar 14, 2003 10:43 AM
FD3S
Mar 4, 2003 04:01 AM
B00ST2nR
Dec 13, 2002 10:51 AM
slowredsi
Aug 27, 2002 08:18 PM
