Ls/Vtec Help. what am i doing wrong?
Old Jan 24, 2005 | 10:57 PM
DIYMIKE's Avatar
Default Ls/Vtec Help. what am i doing wrong?
i recently did a LSVTEC. it ran fine for a couple days. then it starts to knock on me. pulled the spark plug to hear better. and the valves are hitting the pistons. i time it to find out that When i rev the cam gears start to misalign. the intake cam goes up and the exhaust cam goes down. at idle it doesn't knock only when there is tension when i rev higher and the belt streches and the timing goes crazy.
i got a b18a block with a pr3 b16 head. i was on a tight budget so i didn't use a vtec water pump. i kept the block stock. what could it be? the water pump? i used a LS timing belt
Old Jan 24, 2005 | 11:27 PM
mmuller's Avatar
Mad Scientist
Default Re: Ls/Vtec Help. what am i doing wrong? (vtecgenocide)
so the gears are moving when running? did you torque the bolts properly?
i dont think your hitting the valves against the pistons; if so the ''knocking'' would not go away
Old Jan 24, 2005 | 11:34 PM
notstock93's Avatar
Default Re: Ls/Vtec Help. what am i doing wrong? (mmuller)
with the stock LS block you are not in any danger of valve to piston contact unless your running insane amounts of cam degree.
edit- check the cam-caps to see if they are way loose.
Old Jan 25, 2005 | 09:34 AM
DIYMIKE's Avatar
well let me clarify. when i set everything at top dead center and i point the timing gun at the cam gears they are not leveled "--" the intake cam is up and the exhaust is down. when i rev the distant between them increases and it starts to knock louder and faster.
what could it be?
Old Jan 25, 2005 | 09:50 AM
jdmsi1320's Avatar
the first thing you should do is to torque the cam gears to spec. its not good if they advance or retard them selfs when at high rpm. when done with that dont advance or retard the cam gears and see if you still hear a knocking. if you do its most likely not the valves hitting.
Old Jan 25, 2005 | 01:54 PM
DIYMIKE's Avatar
ok i set the timing. its perfect. i start it up and at idle no knock. i rev it to about 2 to 3k and it starts to knock. but if i rev past that to 5 k or higher no knock? please help i don't want to rip this motor apart.
Old Jan 25, 2005 | 02:27 PM
GDM Z28's Avatar
it could be a bunch of different things. do u have access to a video camera so we could see and hear? that would be better
unified112
50
Jan 5, 2013 04:07 PM
MatakiRotorD16
Jul 24, 2011 07:43 PM
Dppope
Apr 13, 2009 06:58 AM
si0385.
23
Aug 30, 2006 12:21 PM
DIYMIKE
Feb 1, 2005 02:22 PM
