Brake pedal drops to the floor, dunning out of ideas
Old Jan 24, 2005 | 06:28 PM
xci_ed6's Avatar
Default Brake pedal drops to the floor, dunning out of ideas
I swapped the brakes between my EX & DX so I could have big brakes on the faster car. Now the EX is having problems. The pedal drops all the way to the floor, but you can pump it up. I replaced the master cylinder & bench bled it, also bled all the wheels. no air is comming out anywhere, but it keeps on doing it. no signs of a leak either.
Any ideas?
Old Jan 24, 2005 | 06:33 PM
crexer's Avatar
Default Re: Brake pedal drops to the floor, dunning out of ideas (krustindumm)
exactly what brake components did you "swap"
Old Jan 24, 2005 | 06:35 PM
HatchBox's Avatar
Skoobie no more...
maybe hook up a T fitting to a vacume guage between the intake manifold and the booster.
maybe the one way valve in that line is bad...
Thats easy to test, Take it out and blow in one end, and blow in the other. it should only accpet air one one.
Old Jan 24, 2005 | 07:16 PM
xci_ed6's Avatar
Default Re: Brake pedal drops to the floor, dunning out of ideas (HatchBox)
the booster will have nothing to do with the pedal dropping.
I swapped front spindle assemblies and master cylinders. That is all.
Old Jan 24, 2005 | 07:24 PM
crexer's Avatar
If you bled all the lines the proper way, maybe even several times and the pedal is still going to the floor, then the problem has to be in the master cylinder. Try using your old one. Did you pick one from a junkyard?
Old Jan 24, 2005 | 07:27 PM
xci_ed6's Avatar
Default Re: Brake pedal drops to the floor, dunning out of ideas (crexer)
tried both the EX & DX master cylinders
Old Jan 24, 2005 | 07:28 PM
HatchBox's Avatar
Skoobie no more...
if there is no atmosheric pressure then it wont pressure, giving you petal firm ness...
take off that line going to the intake manifold on a normal car and the petal willl go to the floor.
Old Jan 24, 2005 | 07:54 PM
xci_ed6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">if there is no atmosheric pressure then it wont pressure, giving you petal firm ness...
take off that line going to the intake manifold on a normal car and the petal willl go to the floor.</TD></TR></TABLE>
keep on thinking that buddy
intake manifold vacuum has nothing to do with hydraulic circuit pressure.
I am after all a tech @ a Honda dealership. I am just running out of ideas other than the calipers are fucked, and i dont want to replace them unless i know for sure.
Old Jan 24, 2005 | 07:57 PM
HatchBox's Avatar
Skoobie no more...
sorry for trying to help.
2theekidd3
May 10, 2013 04:01 PM
ice11honda
Feb 24, 2005 12:56 PM
LAKER HATER
Nov 10, 2004 04:36 PM
magbarn
May 22, 2003 03:28 PM
Draco
Feb 12, 2003 04:24 AM
