motor blows smoke after 5200rpm
Old Jan 24, 2005 | 06:03 PM
661's Avatar
661
Default motor blows smoke after 5200rpm
Well i was on the freeway and as i passed 5200rpm i blew massive blue/ grey smoke, then it fadded away as i dropped underneath 5200rpm. Motor makes a ticking sound as if the valves were messed up but im not sure. When the car is cold it sputters. Oh, the car is a 1990 crx si with a b16a
any ideas?
Old Jan 24, 2005 | 06:33 PM
crxtreme89h's Avatar
Default Re: motor blows smoke after 5200rpm (661)
Well 5200 is about when the Vtec kicks in on mine. That shouldn't make that much of a difference though. Did you just recently swap the motor? If so, you could just be burning off whatever sat in the motor for so long. I don't know. Head gasket maybe?
Old Jan 24, 2005 | 06:44 PM
trrbl1bmx's Avatar
yeah pending on how long you had the motor. it could be lots of things. you might need a valve job. try fuel system cleaner. Just troubleshoot it. Good Luck.
shocker's Avatar
could just be tuned bad,to much fuel or not enough fuel.....
Old Jan 24, 2005 | 07:02 PM
civic hatch_b18C5's Avatar
ur are burning oil in V-TECH and ur piston rings are bad
Old Jan 24, 2005 | 09:17 PM
31flavorscivic's Avatar
Default Re: motor blows smoke after 5200rpm (civic hatch_b18C5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic hatch_b18C5 &raquo;</TD></TR><TR><TD CLASS="quote">ur are burning oil in V-TECH and ur piston rings are bad</TD></TR></TABLE>
Phones can burn oil? haha just playin.
Where did you get that motor? If it wasn't from an importer then it could have been driven like it was stolen before you put it into your car. I'm betting on the rings.
Also please make sure you have correct amount of oil in the car. I know vtec usually doesnt engage without it, just always good to make sure.
Old Jan 24, 2005 | 09:35 PM
hahagasdcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 661 &raquo;</TD></TR><TR><TD CLASS="quote">Well i was on the freeway and as i passed 5200rpm i blew massive blue/ grey smoke, then it fadded away as i dropped underneath 5200rpm.</TD></TR></TABLE>
Could be bad rings. Also and more than likely leaking valve stem seals. Blow a little smoke when you first crank it up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 661 &raquo;</TD></TR><TR><TD CLASS="quote"> Motor makes a ticking sound as if the valves were messed up but im not sure.</TD></TR></TABLE>
Most first gen. B16's Lost Motion Assemblies go bad after all the motors are like 12+ yrs old. Bad LMA's cause the Vtec lobe rocker to basically flap under the cam when not in VTEC. If the ticks go away when VTEC is engaged that would more than likely be the cause of your ticking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 661 &raquo;</TD></TR><TR><TD CLASS="quote">When the car is cold it sputters. Oh, the car is a 1990 crx si with a b16a
any ideas?</TD></TR></TABLE>
Maybe your EACV is not wired up correctly or coolant level is low. Timing? maybe? Fuel injector clogged or not getting a signal.
Old Jan 25, 2005 | 05:46 AM
subydoored's Avatar
Default Re: motor blows smoke after 5200rpm (hahagasdcrx)
rings could be bad
head gasket
carbon build up in the valves
burning old oil
to rich in the fuel
Old Jan 25, 2005 | 05:53 AM
mellon's Avatar
Default Re: motor blows smoke after 5200rpm (subydoored)
Sounds like the rings or the headgasket to me. Isn't the smoke black when you are running rich?
Old Jan 25, 2005 | 06:32 AM
PaImportTuner's Avatar
Default Re: motor blows smoke after 5200rpm (mellon)
rings/headgasket is grey/blue.. rich is black. yes
while your changing rings you might as well build the bottom end and throw in some oversized CTR pistons and readjust valves. and stop getitng cheap fuel. lol
y0whuddupb
Feb 7, 2007 01:36 PM
lil_greencivic
Oct 13, 2006 08:59 PM
Collateral
Mar 14, 2005 10:39 PM
kikwear002
Jan 24, 2005 06:09 PM
