white smoke no honey smell idle (searched)
guys i need your help my B16A3 overheated, ( white smoke honey smell) i changed the head gasket. now when cold runs perfect and no smoke or idle but as soon as it gets warn the engine starts bouncing the idle form 2k-3k back up and down and puffs of smoke it smells like rich gas or somethign iritating but no honey smell what can it be some one help!!!!!!! please thanks guys
ok i took off the intake today and clogged the little hole in the tb and ran fine it didnt idle what can this be is the aicv clogged or dirty or broke????
Modified by 92b16si at 2:44 AM 1/26/2005
Modified by 92b16si at 2:45 AM 1/26/2005
Whitish exhaust smoke while the engine is cold may be consider normal. But after warmup, white smoke may indicate water or coolant has turned to steam in the combustion camber. Most likely a cracked cylinder head or a blown, misaligned, or over torqued head gasket.......i hope this helps
how much torqwue were are they suppost to be i torqued them to the specs 66 i will it affect it if i torqued it like 1 lb more? also it doesnt smeel like honey and the oil anr coolent dont seem to me mixing it gives like a nasty smell like to much gas like if its not burned right
1 lb won' t make a difference. most torque wrenches are innacurate by that anyways. do a compression test to see whats it is. also did you untorque and retorque the head in the proper sequence?
yeah i torqued it in the right sequense and to 33 then to 66 lbs i believe it was i will do a compression test what does it have to read? also the car seems to run fine when i clogg the hole inside the tb or when the car is cold
your compression numbers don't really mean a whole lot. its just when one or more is different than your others. Thats when you know you have a leak somewhere. i.e. valves, rings, headgasket.
what do you mean by clogging the tb? Like cover the entire hole???
no not the whole tb the car runs fine until it gets hott then it idles and smokes i just clogg the small little hole that inside the tb the one that goes to the aicv( i think its called) and it runs fine
tony7626
Mar 27, 2009 10:48 PM
5Point7Liter
Sep 22, 2008 04:46 PM
YellowR2000x2
May 22, 2005 02:04 AM
arabtitalator(civic'si)
Sep 23, 2004 09:38 PM
