Are 94+ integra double din or smaller???
I'm asking bc I'm interested in putting an Eclipse AVN2454 Double-Din DVD/GPS Navigation System in my 2001 teg. I looked on crutchfield.com for a similar item (kenwood double din one) and it says it wont fit.
The integra's look like they are double din but I could be wrong. Can someone verified this with me?
Here's the specs:
6.5" wide, low glare panel
Dimensions 7"(w)x4"(h)x6-1/2"(d)
Here's the specs:
It is double din but they don't say it will fit because there are no brackets available to bolt it in. You can make your own and it probably won't take more then a couple of tries to get it to work. Possible that the trim ring may present problems as well.
use the metra double din kit from metra
this is where i ordered mine
http://www.partsexpress.com/pe...5-833
yup..it's double din capable...just gotta get the Honda/Acura double din kit from metra....Circuit city stores should carry it in stock for about $20.
i just installed a double din kenwood in my integra.
i have to grind out all the plastic on the top and bottom for it to fit.
now it fits like a glove.
I have an Alpine CDA-7894, and Im thinking about installing a aftermarket tv screen right on the bottem. Do you think it'll be an easy install with that kit, or how hard is it to install that kit? I know you gotta trim the sides off and stuff...but is it necessary to take the panel out and install it and then put the panel back on? and did u have to bent the metal on the inside of the integra...cuz i Know that can be a problem too...?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rathead »</TD></TR><TR><TD CLASS="quote">i just installed a double din kenwood in my integra.
now it fits like a glove. </TD></TR></TABLE>I did that on my last setup for my cd, eq, dsp, now I changed my dsp and it has a lip on the unit. I now need like 3-4 mm more room for it too fit and my plastic now wont fit and its cut almost to max. Is there any other kit that could fit this with an extra 4 mm room?
Mr.DC2TurBo
Audio / Security / Video
16
Aug 27, 2004 09:50 PM
