OIL OWNES MY MOTOR
Old Jan 24, 2005 | 09:59 AM
ITR-00-1457's Avatar
Default OIL OWNES MY MOTOR
Straight up, because I am tired about dealing with my motor/caR.
The other day I noticed an oil spot on the ground under my car, I looked under and saw some oil on the tranny housing. After poping the hood I noticed that there was some oil coming from the front left side of the motor (tranny side) where the head and block meet, trickling down. Concerned I pulled the plugs finding all four were the same. The threads and electrodes were covered in oil. The body of the plug were the wire attaches was completely clean, almost new looking.
Now, I have had blown headgaskets before and the motor did not respond like this. Normally you are able to tell exactly which cylinder failed, but here they all look bad. Also there was no real blue smoke coming out of my tail pipe for the most part. At high rpms there would be some if I got on it real hard but that is normal. My oil pressure has also seemed to have dropped some as well.
Any and all opinions!
Old Jan 24, 2005 | 10:03 AM
RTW DC2R's Avatar
are u sure the plugs were covered in oil and not carbon/fuel deposits? i would think if there was that much oil on the plugs, you would definitely notice smoke from the exhaust.
Old Jan 24, 2005 | 10:07 AM
Its_real&its_spectacular's Avatar
New User
Default Re: OIL OWNES MY MOTOR (ITR-00-1457)
What is likely is that either the valve cover seals at the spark plug holes are leaking or the o-ring seals a little farther down in the plug hole are leaking. Doesn't take much oil to leak down there and when you pull the plug out, it all dribbles down the threads onto the electrode.
If there's only a little down there, then it won't get the wires all messy.
Hopefully its the simplest fix... Valve cover seals...
Old Jan 24, 2005 | 10:09 AM
Big Phat R's Avatar
stock motor or modded?
RTW DC2R's Avatar
he said that side of the plug is clean though
Old Jan 24, 2005 | 10:41 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR-00-1457 &raquo;</TD></TR><TR><TD CLASS="quote">Any and all opinions!</TD></TR></TABLE>
Did you remember to install the head gasket?
But seriously, when was the last time you had the head off? Are you SURE your plugs are fouled with oil, or just carbon? Can you post a picture?
Any chance it's the valve cover and not the head?
Sounds like a head gasket to me, but I can't imagine all of your cylinders really have oil, I think you're just seeing old/carbon fouled plugs.
-Chris
Old Jan 24, 2005 | 10:58 AM
Default Re: OIL OWNES MY MOTOR (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">stock motor or modded?</TD></TR></TABLE>
Pretty modded.
I was talking with the guy that built my motor and he said that it might be the valve cover spark plug rubber seals. I am gonna try and get a kit today.
And it was definately oil, and not carbon deposits, it was all "oily". I already cleaned them off so picks wont really help.
Now what about the fact that there is a leak between the head and the block? Is that just a coincidental occurance with the fact that the rubber seals are bad? Or is that a head gasket issue as well?
Old Jan 24, 2005 | 11:49 AM
RTW DC2R's Avatar
could be a head gasket, or possibly a "warped" head. if its really bad, I would probably end up pulling the head. and if I was gonna pull the head, Id send it out to a machine shop to make sure its flat. same goes for the block. assuming that hasnt been done already.
Old Jan 24, 2005 | 01:19 PM
Default Re: (RTW DC2)
well actually it has the head was milled and the block was decked when I rebuilt the motor 2 months ago. everything was checked. and the plugs only have about 3k on them.
Old Jan 24, 2005 | 01:22 PM
totsie7944's Avatar
Sounds like a headgasket to me. Park the caR for a few days and take the head off and check everything out.
Old Jan 24, 2005 | 03:17 PM
Big Phat R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">could be a head gasket, or possibly a "warped" head. </TD></TR></TABLE>
Since your head was milled and decked - I think the same
Old Jan 24, 2005 | 04:39 PM
Default Re: (Big Phat R)
well I just spent a couple hours with the car. I pulled the headers off, as well as the tranny brace, checked all the oil pan bolts, cleaned up all the excess oil, so maybe I can have a better idea as to where it is coming from. I also changed the plugs, drove around a little bit, rechecked them and there was no oil on them now. So I have no idea what is going on.
Old Jan 24, 2005 | 04:42 PM
RTW DC2R's Avatar
Default Re: (ITR-00-1457)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR-00-1457 &raquo;</TD></TR><TR><TD CLASS="quote">well actually it has the head was milled and the block was decked when I rebuilt the motor 2 months ago. everything was checked. and the plugs only have about 3k on them.</TD></TR></TABLE>
I actually had a head gasket leak after my motor was built too, even though the head was milled and block was decked. I had to get them redone and everything was fine after that.
Old Jan 24, 2005 | 05:00 PM
I really hope that that is not the problem, I am really tired of taking the motor out of my car.
gooberwolf
Dec 24, 2008 08:43 AM
picturethis
Oct 2, 2007 05:01 PM
magic hat #9
Apr 21, 2004 02:24 PM
Nextelbuddy
May 30, 2003 07:50 AM
