9 miles to gallon.. swapped cx.
Old Jan 24, 2005 | 08:24 AM
93CX's Avatar
Default 9 miles to gallon.. swapped cx.
I can no longer afford to fill my tank up every other day so I come to h-t in search of help. I have a 93 cx hatch swapped with a 97 gsr b18c1 running obd-1. Ever since I got this thing on the road I've been getting shitty gas mileage but I havent been worrying because I've had a bunch of cash and no problems refilling my tank. But now I'm broke, and I calculated my gas mileage last night. Under 100 miles to a tank! I cant afford to do this anymore. Can someone give me some beginners tips on checking it out and what to look for causing this? Also my cars been shooting tons of white smoke out of the back.. I was hoping it was just because of how cold it is, but I dont think thats the case.
Sigh, TIA
Old Jan 24, 2005 | 08:26 AM
slowhatch4now's Avatar
Default Re: 9 miles to gallon.. swapped cx. (93CX)
Gas leak
check all your fuel pipes, Mainly check the gas Tank itself for a leak, next check out the fuel return and the fuel rail and where the 2 lines go into the rail. Im saying its a gas leak.
Peace
Old Jan 24, 2005 | 08:27 AM
dantastic's Avatar
what ecu/chip are u running? what mods?
Old Jan 24, 2005 | 08:28 AM
knockout's Avatar
Default Re: 9 miles to gallon.. swapped cx. (dantastic)
whats the stock MPG for a b18c1 anyways??
Old Jan 24, 2005 | 08:37 AM
93CX's Avatar
Default Re: 9 miles to gallon.. swapped cx. (knockout)
uberdata p72. i didnt install it. no mods. filter clamped to tb
my car is also idling horrible.. when you first start it up in the morning it can go as high as 2700, but will settle down to 1400. when its been on for a while (more than an hour) it dips to 1k.
Old Jan 24, 2005 | 08:45 AM
eK9aT10pSi's Avatar
possible o2 sensor problem/installaiton ?b dirty injectors ? bad plugs ?
Old Jan 24, 2005 | 08:46 AM
2lua's Avatar
do you got any cel? everything hook up? need more info on the condition of the car.
Old Jan 24, 2005 | 08:50 AM
civicboisi's Avatar
stock mpg on a b18c1 is definitely not 9 miles to the gallon...
filter clamped to the TB? you don't have an arm?
Sounds like you might have air in your coolant that's causing it to idle kinda high before dropping...any check engine lights btw?
Bad gas mileage is usually: Bad fuel filter (cheap and easy to fix) bad plugs (not enough spark could lead to fuel loss) bad injector, bad O2 sensor, dead cat.
Also, you're running premium grade gas right? Next time you fill up, set the odometer and drive it till you're bout 1/4 tank, then let us know what your at.
Under 100 miles to a full tank, there's something DEFINITELY wrong...you're getting robbed!
Old Jan 24, 2005 | 09:01 AM
Lee_Delso's Avatar
Default Re: 9 miles to gallon.. swapped cx. (civicboisi)
My guess would have to be a gas leak somewhere in your car, even though you may be running rich that still doesn't explain 9 mpg.
Old Jan 24, 2005 | 09:03 AM
GULLIE EG's Avatar
my car was doing the same exacft thing after my swap, it ended up being my TPS sensor. Check it out.
Old Jan 24, 2005 | 10:00 AM
93CX's Avatar
Default Re: 9 miles to gallon.. swapped cx. (GULLIE EG)
my cat is brand new. everything else that was mentioned I will definatly look into.. no I dont have an arm for the intake. I will get one. Is draining the coolant as simple as a plug on the bottom of the radiator?
uh. i'm probably gonna get flamed for this but do I have to be using supreme gas? :X
Old Jan 24, 2005 | 10:06 AM
b18CivicEx's Avatar
i have the same engine. when i start my car in the morning i get up to about 2700 rpms also but after 5 mins it goes down to under 1.
and yea i get like about 27 mpg
i use regular gas
Old Jan 24, 2005 | 10:21 AM
civicboisi's Avatar
Default Re: (b18CivicEx)
premium guys...PREMIUM is minimum for this motor i believe...running cheap 87 grade gas could affect the proformance of the motor i believe...and also on the gas door and cluster it calls for premium i think too...
You dont have to drain the coolant...just check the level...open the cap and look to see if it's full...if not, start the car...let it warm up and start adding coolant till it gets full.
Good luck
Old Jan 24, 2005 | 10:29 AM
POE's Avatar
POE
you checked your o2 sensor? for sure.
Old Jan 24, 2005 | 10:40 AM
95dxhatch's Avatar
its gotta be a combiination of things. o2 alone wont cause that. i'm throwing my o2 code and am still getting 36mpg in my z6 swapped hatch. yea i know its a little different then b18c but still. check your fuel system 9mpg is messed up. good luck
Old Jan 24, 2005 | 10:44 AM
POE's Avatar
POE
Default Re: (95dxhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxhatch &raquo;</TD></TR><TR><TD CLASS="quote">its gotta be a combiination of things. o2 alone wont cause that. i'm throwing my o2 code and am still getting 36mpg in my z6 swapped hatch. yea i know its a little different then b18c but still. check your fuel system 9mpg is messed up. good luck</TD></TR></TABLE>
yeah that is true, BTW, your car is clean, when you gonna get a lip for it?
Old Jan 24, 2005 | 10:45 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (Vtecin94dx)
You would be able to smell a gas leak...
Old Jan 24, 2005 | 11:13 AM
90gs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GULLIE EG &raquo;</TD></TR><TR><TD CLASS="quote">my car was doing the same exacft thing after my swap, it ended up being my TPS sensor. Check it out.</TD></TR></TABLE>
correct me if i'm wrong but i've always heard that gas mileage is dominantly determined by throttle position, which would make sense. i've heard many stories of guys in v8s getting a lower final drive and they get better gas mileage around the city because they dont have to hit the gas as hard to get moving. also if the car thinks you're at WOT then you're mpg would go way down
Old Jan 24, 2005 | 04:14 PM
93CX's Avatar
Default Re: 9 miles to gallon.. swapped cx. (90gs)
Its definatly possible my spark plugs are shot.. I bog under WOT where my car just cuts out and stops accellerating, and my friend said that was because of shitty spark plugs. I'll definatly look into replacing those
Old Jan 24, 2005 | 04:18 PM
jlacoy82's Avatar
71.192.16.183
What about the MAP sensor? Is there a IACV on that motor as well?
Old Jan 24, 2005 | 04:23 PM
degooser's Avatar
i would do a complete tune up on your car...
oil, plugs, wire, dist cap, rotor, o2...
basically the basics...that mileage is wack..i even get better mileage with a cable b16 tranny on my gsr motor...with a chipped ecu....
oh. premium fuel all the way..
Old Jan 24, 2005 | 05:43 PM
futurefastguy's Avatar
Default Re: 9 miles to gallon.. swapped cx. (degooser)
dude, if you have a gsr motor, you MUST use premium. you motor would run shitty without it.
Old Jan 24, 2005 | 06:22 PM
HONDA92HATCH's Avatar
Default Re: 9 miles to gallon.. swapped cx. (futurefastguy)
my buddys h22 accord was doing the same stuff yours is it was the fuel filter he put a new one in it now it runs better than ever
Old Jan 24, 2005 | 06:29 PM
RedDC5's Avatar
Man check into the ECU and also look at your spark plugs, those things can affect gas mileage if they are not kept up.
team 15
Mar 29, 2011 02:36 PM
lv6l
11
Oct 16, 2005 04:36 PM
92sleepR
11
Feb 26, 2003 05:25 PM
beakert216
Aug 8, 2002 08:08 AM
RATEDR
12
Mar 22, 2002 04:29 AM
