Is there any pressure coming from the oil return line in the turbo?
Old Jan 13, 2002 | 05:05 AM
karmannghia's Avatar
Default Is there any pressure coming from the oil return line in the turbo?
I am trying to decide the proper Earls' fittings to go with my oil return line. Alot of people here suggest size AN 10 which equal out to be around 1/2. The shop where I can get it locally stock mostly AN 08 which is about 3/8. Will the oil in the turbo back up and causes to burn oil if I use the AN 08?
Old Jan 13, 2002 | 09:32 AM
earl's Avatar
Default Re: Is there any pressure coming from the oil return line in the turbo? (karmannghia)
No real pressure (other than gravity and the weight of the oil). U don't want oil backing up on you so that's why the larger diameter is more effective. U can even do this with plain old hi-temp black hose although the braided is sweet.
Old Jan 13, 2002 | 09:34 AM
bigTom's Avatar
fyi... -8 is 1/2 inch and -10 is 5/8's
Old Jan 13, 2002 | 07:06 PM
turbopimp's Avatar
Go with the -10... better safe than sorry...
Old Jan 13, 2002 | 07:16 PM
turbocoupe's Avatar
Default Re: Is there any pressure coming from the oil return line in the turbo? (turbopimp)
don't use the black hose. . .mine hit the downpipe. . .made a whole. . .hehehehe that sucked. . .I used a 1.2 brass fitting from a hydrolic store with a steel braided line. . .works for me. ..good luck.
sampol999
Sep 3, 2006 01:09 PM
SiR99
Jun 11, 2006 09:09 PM
MotorMouth
Mar 20, 2006 07:12 PM
delslowh23
Feb 28, 2004 04:59 PM
Blown90hatcH
Dec 26, 2001 11:26 PM
