carbon fiber cutting??
Old Jan 24, 2005 | 06:52 AM
WREKONIZE V8 KLR's Avatar
Default carbon fiber cutting??
i just recieved a franks custom carbon fiber dash and need to mount my gauges and switch box. as you know auto meter gauges need a round cut hole, would i be better off using a dremel with a rotor-zip style attachment and slowly make the cut, or get a hole saw bit? will it splinter with the bit? also the tach and speedo need a large hole i think around 4 inches, hole saw or freehand dremmel? the painless box needs a straight line cut about 6 inches long . needless to say i am very nervous about cutting up my new dash please help. thanks in advance
Old Jan 24, 2005 | 08:04 AM
Default Re: carbon fiber cutting?? (WREKONIZE V8 KLR)
bump...
Old Jan 24, 2005 | 09:16 AM
jweller's Avatar
I used a dremmel on it when I cut a piece of finished CF. I used one of the cut off disks to rough cut the outside of the circle, and then opened it up with a sanding drum. I also taped over the finished side to protect it from scratches and to prevent splintering. took forever but it turned out good.
Old Jan 24, 2005 | 10:04 AM
david@didrace.com's Avatar
A holesaw works fine. Just put masking tape around the circumference of the hole so it will cut smooth.
Old Jan 25, 2005 | 08:43 AM
hondadesign's Avatar
Default Re: carbon fiber cutting?? (backpurge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge &raquo;</TD></TR><TR><TD CLASS="quote">A holesaw works fine. Just put masking tape around the circumference of the hole so it will cut smooth.</TD></TR></TABLE>
word....Ive done it that way for awhile now
Old Jan 25, 2005 | 11:29 AM
kb58's Avatar
Banned
Default Re: carbon fiber cutting?? (hondadesign)
Make sure to use a vacuum while you cut it!
Old Jan 25, 2005 | 12:30 PM
nonsense's Avatar
Default Re: carbon fiber cutting?? (kb58)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 &raquo;</TD></TR><TR><TD CLASS="quote">Make sure to use a vacuum while you cut it!</TD></TR></TABLE>
is that to keep carbon particles out of the motor? I've read that cutting CF with a dremel can kill the motor if carbon builds up inside it.
Old Jan 25, 2005 | 04:33 PM
Default Re: carbon fiber cutting?? (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">
is that to keep carbon particles out of the motor? I've read that cutting CF with a dremel can kill the motor if carbon builds up inside it. </TD></TR></TABLE>
YERP, Cf is conductive and will wipe out the brushes
Old Jan 27, 2005 | 09:14 AM
jweller's Avatar
good to know, even if it is better late than never.
at least you can replace the brushes
Old Jan 27, 2005 | 09:18 AM
ITRacer121's Avatar
I would wear a mask too that stuff is not good for your lungs either
jdmxsi92turbo
Welding / Fabrication
Feb 5, 2011 07:31 PM
9seccivicsi
Sep 18, 2004 09:03 PM
crx12
Jan 14, 2004 07:28 AM
20lb.teg
Nov 9, 2002 07:00 PM
BlueSi
Jan 21, 2002 03:05 PM
