Attn: high horsepower R's
Old Jan 23, 2005 | 11:47 PM
Erik B's Avatar
Default Attn: high horsepower R's
Hey what up guys? Hey what kinda axles are you guys running? I'm looking for something that'll hold about 500whp plus? Also what size rims/slicks are you guys running? Brake clearing issues?
I'll be running DR for the time being till I get more info. Thanks guys for any feed back
Old Jan 24, 2005 | 04:06 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: Attn: high horsepower R's (Erik B)
Forced induction and drag racing forums are a good place to look.
500whp axles are 500whp axles regardless if you have an "R" sticker on the side of your car or not.
Old Jan 24, 2005 | 04:52 AM
Bbasso's Avatar
start with this. https://honda-tech.com/zerothread?id=1117962
Old Jan 24, 2005 | 05:14 AM
PM-Performance's Avatar
Default Re: Attn: high horsepower R's (Bbasso)
i was running Advanced Auto axles and they held good until i started 2nd gear burnouts on Dr's. DSS or Gators are the way to go, just bite the bullet and get stage 5-6
Old Jan 24, 2005 | 06:00 AM
DontBlink's Avatar
Default Re: Attn: high horsepower R's (itr206)
im running stock axles right now, broke my fist stock axle with 95k on them at the end of racing last year( still able to limp 1.5 hours home from the track). im looking into getting some gator axles for mine, they're a little less than drive shaft shop,axles but that will be your choice on what you wanna spend. as for rims im runnin 15x6.5 regamasters, i have a 5mm spacer for the 225/50/15 drag radials i run everday, but they still rub a little at full steering lock. as far as slicks , i havent ran them yet, but when i do they'll be the 24.5x8x15( i think thats the size) and i'll use a 15x7" rim.
Old Jan 24, 2005 | 08:56 AM
99 TYPE R's Avatar
Default Re: Attn: high horsepower R's (DontBlink)
As already stated Gator Axles--- Good pricing, Awesome product check out there webpage http://www.gatoraxles.com they have some good shiot!
Old Jan 27, 2005 | 01:38 AM
Erik B's Avatar
This regards my ITR, I wanted to hear from the ITR guys...is that ok with you Activearo?
Anyway thanks allot guys. I found the info I needed with your posts!
<-Wonders why people troll posts they have nothing to contribute too
Old Jan 27, 2005 | 04:21 AM
btotherizzle's Avatar
gator stage 2 for me, I've never run slicks but I feel more piece of mind when I'm wheel hopping down the track. I just can't make the stockers last.
Old Jan 27, 2005 | 05:06 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: (Erik B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik B &raquo;</TD></TR><TR><TD CLASS="quote">This regards my ITR, I wanted to hear from the ITR guys...is that ok with you Activearo?
&lt;-Wonders why people troll posts they have nothing to contribute too</TD></TR></TABLE>
I think because even the guys with the ITR's, or any hondas, whom are making high power on the board, are lurking in the forced induction and drag forums.
I think you should rethink how you were looking at things.
Also, to give you further insight:
-bogart is the way to go for you, wheel wise. Dont play around with it, run some good slicks, or even a radial, on those. If not, then a 15x7 slip will do the job just fine, unless you have to have the real deal.
-Driveshaft shop stage 2 or 3 will even hold it. You will not be ******* the car everyday, and if my friends local can use stock axles with a 517hp gsr and hold up on em for over 6months of street racing, you can use those stage 2 or 3's all day long.
-as far as a radial goes, you will do well with some Michelins, or Nittos. They both hold up, as i have used both. Toyo has one, but im not sure how good it holds up, because i have never used it personally. You should look into traction bars when running radials.
Old Jan 27, 2005 | 06:12 AM
Default Re: (.Stunna.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Stunna. &raquo;</TD></TR><TR><TD CLASS="quote">
-as far as a radial goes, you will do well with some Michelins, or Nittos. They both hold up, as i have used both. Toyo has one, but im not sure how good it holds up, because i have never used it personally. You should look into traction bars when running radials.</TD></TR></TABLE>
Bogarts are the way to go for running slicks.
For radials Stockers are more then fine. If not step up to a 7inch wide wheel
Michelins for DR's? Wouldnt trust them , Nittos usually suck for there DR's too
BFG is the top dog for sticky DR's right now. YOu will break axles on them though. Eventually it will happen. If you plan on racing it alot, just get the bigger axles and be done with it. If not get stage 3's and run the risk of breaking them.
You should look into traction bars reguardless if its a FWD car. They help a ton
Old Jan 27, 2005 | 06:15 AM
Bradstard's Avatar
I'm running driveshaftshop stage 3's but I make no power compared to some of the big turbo R's.
Old Jan 27, 2005 | 06:26 AM
Chris F's Avatar
Default Re: Attn: high horsepower R's (Fat Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">I'm running driveshaftshop stage 3's but I make no power compared to some of the big turbo R's. </TD></TR></TABLE>
I run stock, but again see above ^^^ 222 ft-lbs torque with the Action 1MD, I'd have to do something pretty stupid to snap an axle
-Chris
Old Jan 27, 2005 | 07:20 AM
totsie7944's Avatar
I'll have to get back to you and this thread tongiht. I have a friend with a GSR with tuned near 600 wheel and a 200 shot behind that so he is looking at over 700 wheel with the shot.
I already know he is runnign 1000horsepower axles. I will run by his shop today and ask him what kind they are and get back to you.
Old Jan 27, 2005 | 07:45 AM
Default Re: Attn: high horsepower R's (totsie7944)
they are prob DSS stage 6's. As far as i know they are the only ones that exist for that kind of power for a Honda
Old Jan 28, 2005 | 12:37 AM
Erik B's Avatar
m going with the Gator stage 3's. They utilize a 300M materials for high aggressive launch and larger slicks (up to 26" tall and 9" wide). They are rated at 650-700whp which is going to be more then enough. Also they do not requires any hub change, so you can retain the stock honda hub without compromising drivability and streetability. (Dam sounds like I'm trying to sell these things huh?)
Anyway, Stunna, I read in those 2 forums allot. Plus I hit up Tony and Art with tons of questions as well as Kenny from Jotech (who is building the motor for me) and get everyone's point of view on things. I drive a ITR so I figured I'd ask another ITR guy or gals what they thought, feel me? Not that bigga deal but I'll post questions related to my R here before I post it in the regular Integra forum....that's what this forum is about. I has always and will always feel if you don't have anything to contribute to a topic just dont even click on it. I mean if you wanna read it and maybe take something outta it then ok...but dont tell me to post my question some where else just cuz there's someone in there who might could answer my question too if I could get answers here. Anyway I wasted enough time on that.
Once again thanks to all the ITR pimps who helped!
Old Jan 28, 2005 | 03:00 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Good grief sorry for trying to direct you to another forum.
If I said something like "hey you dumb **** get out of here" I could see you getting ticked, but I didn't.
I accept your future apology
Old Jan 28, 2005 | 05:23 PM
Stunna BEN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik B &raquo;</TD></TR><TR><TD CLASS="quote">m going with the Gator stage 3's. They utilize a 300M materials for high aggressive launch and larger slicks (up to 26" tall and 9" wide). They are rated at 650-700whp which is going to be more then enough. Also they do not requires any hub change, so you can retain the stock honda hub without compromising drivability and streetability. (Dam sounds like I'm trying to sell these things huh?)
Once again thanks to all the ITR pimps who helped!</TD></TR></TABLE>
Something tells me i wana see pics of your R...
Old Jan 29, 2005 | 05:38 AM
Erik B's Avatar
lmfao....hahaha aiight
Stunna I have pictures on my site (unless you meant after the motor re-build)
http://www.kutsujuracing.com/v...r.php
If you click "view photo gallery" you'll see more pictures. (I sold my GTU's and I'm waiting for custom Volk's to be made, it's been 9 weeks already )
Old Jan 29, 2005 | 06:22 AM
Curt941's Avatar
BADONKA DONK!!!
Old Jan 29, 2005 | 08:37 AM
hYpE-R-29's Avatar
Default Re: (Curt941)
^^^^^^ ..im scared of her!!...she looks like she can hurt me
Old Jan 29, 2005 | 10:07 PM
Erik B's Avatar
lmfao...hahahaha I had a feeling someone would post that..hahahaha Yes she's white tO yO...haha
Old Jan 29, 2005 | 11:07 PM
Kicker773's Avatar
lol
Old Jan 29, 2005 | 11:36 PM
.water's Avatar
Default Re: (hYpE-R-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hYpE-R-29 &raquo;</TD></TR><TR><TD CLASS="quote">^^^^^^ ..im scared of her!!...she looks like she can hurt me </TD></TR></TABLE>
hahahahaha she is bigger than me
killerpenguin21
Mar 10, 2010 04:56 PM
Flexin5
Sep 15, 2006 03:08 AM
turboman
Feb 20, 2006 11:40 PM
mrbsponge
Sep 11, 2005 08:54 PM
Rocks
May 2, 2005 11:16 AM
