Psi Question
Old Jan 23, 2005 | 10:26 PM
bryandamatrix's Avatar
Default Psi Question
okay i have 205/45 R17 Falken tire PLus 3 size
what would be my PSI .....i just check mine today it was running on 25PSI geez thats why my gas milleage are hitting high. i put it to 29 warm psi.
I am scared to putting more higher cuz it said highest psi is 50PSI or 40PSI.
I drive highways 4x a week going to school ....humps 2 or 3
i need specifications what is the requrement for the tire. Front wheel drive.
Old Jan 23, 2005 | 10:32 PM
Stoich EG2's Avatar
Default Re: Psi Question (bryandamatrix)
check the sides of the door sils. where the door latches to the car.
Old Jan 23, 2005 | 10:48 PM
Default Re: Psi Question (Advan06)
in the door sill its stock PSI ...i got a new tire and wheels .....
Old Jan 23, 2005 | 10:54 PM
ricepicker's Avatar
I have 215/45/17 and I run 40 PSI in my tires cold. during the warm months you will want to check them, because heat makes the air in the tires expand. But you should be fine with 40.
Old Jan 23, 2005 | 11:05 PM
GuestHead's Avatar
Default Re: Psi Question (ricepicker)
i run 35 in mine, and they are 205x40x17
Old Jan 24, 2005 | 03:28 AM
'00Accordster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricepicker &raquo;</TD></TR><TR><TD CLASS="quote">I have 215/45/17 and I run 40 PSI in my tires cold. during the warm months you will want to check them, because heat makes the air in the tires expand. But you should be fine with 40.</TD></TR></TABLE>
40 is pretty damn high, and air expands once the tires are warmed up, which is after a block or two. your tire pressure is more like 45-50 when your driving, which IMO is risky. put it down to 32psi cold.
Default Re: Psi Question ('00Accordster)
ive got 2154517, and ive got 32psi cold
B_Swapped93
Mar 24, 2014 05:09 PM
..::91TEG-G2::..
Nov 24, 2007 07:45 AM
escape2me
Feb 4, 2005 03:41 PM
.water
Jan 28, 2005 02:32 PM
ahunt01
Jul 17, 2003 04:22 PM
