Fitment of a DC2 Strut Bar onto an EG Chassis
Old Jan 23, 2005 | 08:05 PM
spankey167's Avatar
Default Fitment of a DC2 Strut Bar onto an EG Chassis
My friend is parting out his DC2 and has 2 Spoon strut bars and i want to pick them up for my EG. Im assuming they fit since a lot of people use OEM DC2 strut bars on their EG's. Can anyone confirm this? Thanx
Old Jan 23, 2005 | 08:37 PM
Master23's Avatar
Default Re: Fitment of a DC2 Strut Bar onto an EG Chassis (spankey167)
Yes they'll fit. Though you might have to find some studs to fit through the holes so that you can lock it in place with some nuts. You'll see how it is and what you need to get when you put them on though. Sorry for the bad description.
Old Jan 23, 2005 | 10:03 PM
spankey167's Avatar
Default Re: Fitment of a DC2 Strut Bar onto an EG Chassis (Jspeed23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jspeed23 &raquo;</TD></TR><TR><TD CLASS="quote">Yes they'll fit. Though you might have to find some studs to fit through the holes so that you can lock it in place with some nuts. You'll see how it is and what you need to get when you put them on though. Sorry for the bad description.</TD></TR></TABLE>
I used the OEM Gsr's as an example.. I am picking up Spoon strut bars... Does anyone have any experience with these bars being swapped?
Old Jan 24, 2005 | 10:29 AM
spankey167's Avatar
Old Jan 24, 2005 | 10:32 AM
POE's Avatar
POE
i have a rear spoon sports strut bar on my eg coupe, and if came off a 98 teg.
Old Jan 24, 2005 | 01:54 PM
spankey167's Avatar
Default Re: (Vtecin94dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecin94dx &raquo;</TD></TR><TR><TD CLASS="quote">i have a rear spoon sports strut bar on my eg coupe, and if came off a 98 teg.</TD></TR></TABLE>
thanx for the info how similar of dimensions do the coupes to hatches?
Old Jan 24, 2005 | 02:09 PM
pdiggitydogg's Avatar
all spoon bars for eg, ek, and dc/db's are the same bars.
I had one...sold it (well traded) I was not impressed initially or in the long run. Pivot points on a strut bar ruins the whole concept
Old Jan 24, 2005 | 03:23 PM
Lord Helmet's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">all spoon bars for eg, ek, and dc/db's are the same bars.
I had one...sold it (well traded) I was not impressed initially or in the long run. Pivot points on a strut bar ruins the whole concept</TD></TR></TABLE>
exactlly. that's why I stick to one piece strut bars
Old Jan 25, 2005 | 10:14 AM
Do_Ster's Avatar
i believe depending on what model eg you have, you might have to drill holes for the front strut bar. there should be a circle template on the shock tower area so you know exactly where to drill. someone correct me if i'm wrong.
Old Jan 25, 2005 | 10:32 AM
rodrez.'s Avatar
Default Re: (ntogethernow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntogethernow &raquo;</TD></TR><TR><TD CLASS="quote">i believe depending on what model eg you have, you might have to drill holes for the front strut bar. there should be a circle template on the shock tower area so you know exactly where to drill. someone correct me if i'm wrong.</TD></TR></TABLE>
You're correct for the GSR OEM bar. I think the Spoon mounts to the shock bolts.
Old Jan 25, 2005 | 10:47 AM
POE's Avatar
POE
Default Re: (rodrez.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez. &raquo;</TD></TR><TR><TD CLASS="quote">
You're correct for the GSR OEM bar. I think the Spoon mounts to the shock bolts. </TD></TR></TABLE>
yeah, you are right, PS. the jerk store just called!
Old Jan 25, 2005 | 12:15 PM
doughboy_88's Avatar
that's correct. there's a guide/tutorial on someone doing this...he had to drill into his shock towers to mount an ITR front strut bar, which i ASSUME has the same mounting points as the DC2 bar.
either way, why not test fit the bars since he's your friend?
POE
Mar 3, 2020 04:17 AM
ek9rrr
Jan 11, 2012 08:46 AM
jvtec95
May 14, 2009 05:58 AM
Drew17th
Nov 9, 2007 11:46 AM
yellow blur
Jan 23, 2005 01:18 PM
