2004 accord engine problems
Old Jan 23, 2005 | 06:00 PM
v-tec maz's Avatar
Default 2004 accord engine problems
my dad got this 2004 accord , till 13 k everything was great and engine was running awesome. after 14k i feel a lildrop in the power. also after 3000RPM engines sounds change. its like a blowing air. im pretty sure its not v-tec cause i think it starts at higher RPM. till 3000RPM engine works dry and great and u can feel the pistons moving( u know what i mean) after that its like there is a very high flow of air and i can feel the drop in power. what do u think is the problem?
( sorry for the english problems)
Old Jan 23, 2005 | 06:11 PM
ricepicker's Avatar
Default Re: 2004 accord engine problems (v-tec maz)
Take it to the dealer. should still be under warranty.
Old Jan 23, 2005 | 06:13 PM
srfnscubamunkey's Avatar
Default Re: 2004 accord engine problems (ricepicker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricepicker &raquo;</TD></TR><TR><TD CLASS="quote">Take it to the dealer. should still be under warranty.</TD></TR></TABLE>
:in a yoda voice:..........yes, yes, take it to dealer he said
Old Jan 23, 2005 | 06:40 PM
shadow_ridge's Avatar
Default Re: 2004 accord engine problems (srfnscubamunkey)
blows air? only thing i can think of is the tranny not shifting and catching on the next gear and runs the rpm?
Old Jan 24, 2005 | 06:17 AM
eauto's Avatar
Default Re: 2004 accord engine problems (shadow_ridge)
I concur with shadow_ridge.
The first initial signs of tranny problems.....
Old Jan 24, 2005 | 07:39 AM
v-tec maz's Avatar
Default Re: 2004 accord engine problems (eauto)
i took it to a dealer and they said there is no problems with it. and it just ran out of warranty i dont think there is anything wrong withe transmition! cause the engines sounds different. it doesnt work dry after 300RPM. exactly 3000!
Old Jan 24, 2005 | 07:41 AM
theres no way that a 04 accord is out of warrantee
Old Jan 24, 2005 | 07:46 AM
v-tec maz's Avatar
i have 33k on it. its my dads
Old Jan 24, 2005 | 07:47 AM
v-tec maz's Avatar
srry its a 2003 i wrote it wrong
Old Jan 24, 2005 | 08:01 AM
Filthy Focker!'s Avatar
There is no way it ran out of warranty. Usually, unless your case is exceptional, you should have a 3 year or 60,000 km warranty.
What did the dealership do to try to diagnos your problem?
fs
Old Jan 24, 2005 | 08:20 AM
v-tec maz's Avatar
Default Re: 2004 accord engine problems (filthy_shovel)
you know what actually its my dads car, so im not very sure its out of warranty or not, but thats not my problem. my problem is the drop in power tell if u know what it is. the v-tec kicks in at 4500 RPM right?
Old Jan 24, 2005 | 09:31 AM
v-tec maz's Avatar
bump
Old Jan 27, 2005 | 03:11 PM
m R g S r's Avatar
there is no drop in power, your just used to it. . .
Well if there is a drop, try ait filter, fuel filter, get the injectors cleaned, make sure o2 sensors are working correctly.
What kind of gas do you use?
Old Jan 27, 2005 | 03:38 PM
Bishop Don Shizzle's Avatar
Oh yeah I forgot I can edit my own title! Yay!
Default Re: 2004 accord engine problems (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">there is no drop in power, your just used to it. . .
Yeah a tuneup might be in order.
Still though, how can a year and a half old car be out of warranty? 33K is already past the warranty for a transmission??
Old Jan 27, 2005 | 03:40 PM
m R g S r's Avatar
Default Re: 2004 accord engine problems (Bishop Don A. Shizzle)
I highly doubt that it needs a tuneup, I just think hes used to the power curve. . .
Old Jan 30, 2005 | 04:39 PM
v-tec maz's Avatar
i dont think that it needs a tuneup, i just took it for a tuneup at 30k and they said everything is fine
Old Jan 30, 2005 | 05:38 PM
Caveman74's Avatar
dont they come with a 3yr 36k warrenty?
Old Jan 31, 2005 | 08:27 AM
paxorion's Avatar
Default Re: (Caveman74)
yea even with 33k...there's still 3k worth of warranty...and obviously it ain't past 3 years...whichever dealer you took it to is either lying so badly or don't understand numbers
Old Jan 31, 2005 | 10:35 AM
v-tec maz's Avatar
Default Re: (paxorion)
i think im just used to the power curve like evan said. cause my dad says the same thing
Donald Ethel
Jun 30, 2015 02:57 PM
EFR450
Jul 31, 2013 06:16 PM
Dashsx
Sep 2, 2004 01:20 PM
Stock R
Jun 15, 2003 06:19 PM
RobertMcDonald
Jun 5, 2003 07:13 AM
