integra axles 4 crx?
Old Jan 23, 2005 | 05:29 PM
my crx is rhd's Avatar
Default integra axles 4 crx?
i gotta crx with a fully built b16a, will 90-93 integra axles fit into there ok?
Old Jan 23, 2005 | 05:31 PM
EP3_05's Avatar
Default Re: integra axles 4 crx? (slammed91integra)
Yes as long as you are using a 90-93 integra intermediate shaft.
Old Jan 23, 2005 | 05:35 PM
crexer's Avatar
Default Re: integra axles 4 crx? (91civic)
I had this problem a few weeks ago....Im not sure how to tell what intermediate shaft you have BUT if it has SK7-7 stamped on it then you will need to use the 90-91 integra NON ABS axles. Hope that helps
Old Jan 23, 2005 | 06:03 PM
wtsexton's Avatar
Doesn't matter if its abs or not. They are the same think, one just has a metal ring on the end.
Old Jan 23, 2005 | 06:06 PM
crexer's Avatar
Default Re: (wtsexton)
well hey better to be safe then sorry, i think i would say Non abs then order one for ABS. Anyway check your shaft for sk7-7
Old Feb 2, 2005 | 02:45 AM
aaronhume's Avatar
Default Re: (crexer)
hey so which axles are correct if the halfshaft says sk7-j? I would assume the 91 axles would work... but if one fits better, than I would prefer that, no?
Old Feb 2, 2005 | 08:40 AM
crxdonwon's Avatar
Default Re: (aaronhume)
if abs axles fit go with those because they will be a lot stronger
krysted9354
Apr 9, 2010 02:52 PM
nautica_t
20
Dec 17, 2004 10:48 AM
charjacq
Mar 2, 2003 08:31 AM
ITR1071
Aug 14, 2002 09:10 AM
