Oil pump, Main studs, Z10, and much more. CHEAP!!!!
Old Jan 23, 2005 | 12:37 PM
bottlefedintegra's Avatar
Default Oil pump, Main studs, Z10, and much more. CHEAP!!!!
OEM b16 oil pump (new) $90
ARP GSR/B16 Main Studs (new) $SOLD
Moroso oil filter block off (new) $50
Z10 main girdle (used) $100 SOLD
Z10 Oil Pan and pick up (new)$450 SOLD
Mallory fuel pump 110fi (used) $50
MSD 3 stage retard box (used) $50
Engine mount kit b series into 88-91 civic/crx with shift linkage (new) $185
stock gsr cams (used) $100
cometic head gasket HP 84mm .043 (new) $55 SOLD
Modified by bottlefedintegra at 12:36 PM 1/24/2005
Modified by bottlefedintegra at 2:52 PM 2/9/2005
Old Jan 23, 2005 | 01:23 PM
reaction360's Avatar
Default Re: Oil pump, Main studs, Z10, and much more. CHEAP!!!! (bottlefedintegra)
what motor is the head gasket for? i'll buy it if its for a gsr. let me know.
Old Jan 23, 2005 | 01:32 PM
Default Re: Oil pump, Main studs, Z10, and much more. CHEAP!!!! (reaction360)
Its for b16/gsr/type-r any dohc b series v-tec head
Old Jan 24, 2005 | 03:35 AM
BUMP
Old Jan 25, 2005 | 01:47 AM
BUMP
Lets make a deal
Will send pics if needed
Old Jan 25, 2005 | 12:55 PM
BUMP AGAIN.
Old Jan 26, 2005 | 03:56 PM
PM Bump
Old Jan 26, 2005 | 05:55 PM
Danger's Avatar
coud you do me a favor and post a pic of your z10 block girdle ? ive had one for a year now and i dont know which motor it is for . thanks .
bump for you
Old Feb 8, 2005 | 06:22 PM
QUiKSR20's Avatar
Default Re: Oil pump, Main studs, Z10, and much more. CHEAP!!!! (JonnnyDanger)
Z10 only makes them for the B-Series. You should be able to tell if its for a GSR/Type R or for a B16/LS/B20 ( the GSR / Type R will have all level sections that bolt on.
Old Feb 9, 2005 | 02:05 AM
Danger's Avatar
Default Re: Oil pump, Main studs, Z10, and much more. CHEAP!!!! (QUiKSR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QUiKSR20 &raquo;</TD></TR><TR><TD CLASS="quote">Z10 only makes them for the B-Series. You should be able to tell if its for a GSR/Type R or for a B16/LS/B20 ( the GSR / Type R will have all level sections that bolt on.
thanks
Old Feb 9, 2005 | 11:21 AM
pubestripe's Avatar
u still have the oil pump up fs? have any pics? pm me with details
TateEvan
Aug 8, 2012 11:40 AM
slugzed
Feb 26, 2008 03:33 AM
smooth95
Jun 19, 2007 09:31 PM
klungemonger
Jan 15, 2007 11:34 AM
bottlefedintegra
Feb 19, 2005 01:22 AM
