Difference between the AEM ITR and GSR pulley kit?
Old Jan 23, 2005 | 12:29 PM
Clabbe's Avatar
Default Difference between the AEM ITR and GSR pulley kit?
I have an B18C1 engine and have stumbled across a very cheap AEM Pulley Kit for the Intera Type-R.
I know that AEM has a kit for the GSR aswell but the question I have is, what is the difference between those kits?
Anyone know?
Is it just different lenghts on the belts provided or is it different in the wheel tooth profiles?
Can I fit a ITR kit to a GSR engine and just buy new belts?
Old Jan 23, 2005 | 01:38 PM
IN VTEC's Avatar
Default Re: Difference between the AEM ITR and GSR pulley kit? (Clabbe)
The pulleys are interchangeable. The alternator belt is of a different length, but the power steering pulley should be the same. If not, it's not hard to resize another belt.
Old Jan 23, 2005 | 02:08 PM
Clabbe's Avatar
Default Re: Difference between the AEM ITR and GSR pulley kit? (IN VTEC)
So it´s just a difference in the belts between those models?
And not any difference between the wheels`?
Old Jan 23, 2005 | 02:11 PM
IN VTEC's Avatar
Exactly. I run an ITR crank pulley with a GS-R AEM PS pulley/belt and stock alternator pulley.
Old Jan 23, 2005 | 02:20 PM
Clabbe's Avatar
if I get your right...
You have a ITR in which you use an AEM PS pulley/belt ment for a GSR.
And you use stock alternator...
You have therefor only changed your PS pulley and uses the belt for an GSR on your ITR?
I know i´m slow when it comes to engines but sometimes i´m dumber then ever...
Old Jan 23, 2005 | 07:35 PM
IN VTEC's Avatar
I've got a GS-R (B18C1 block) and accessories. I just happened to install an ITR crankshaft pulley on it. The ITR crank pulley has a slightly smaller diameter AC and alternator drive. The PS drive is same size as the GS-R's crank pulley.
You can use the AEM's Bando belt for the power steering, but the alternator belt is probably of a different size b/w the GS-R and ITR AEM pulley kits.
neo702
Sep 14, 2006 10:12 AM
2fast2accord98
Jan 21, 2006 08:28 AM
JDM978
Aug 6, 2005 06:51 PM
Chris_Bye
Feb 19, 2005 05:25 PM
sackdz
Oct 30, 2002 08:28 AM
