Chipped p28 or p72 for GSR
Old Jan 23, 2005 | 07:09 AM
Jmunk's Avatar
Default Chipped p28 or p72 for GSR
I got a OBD-I GSR swap and i need a ECU. Should i get a p28, chip it and use that or just run the stock p72. With the p28 i know i wouldn't have to wire up the knock sensor, can you still run the p28 and use the IAB's ? If i should use the p28 what chip should i get ? Thanks.
Old Jan 23, 2005 | 08:05 AM
Luserkid's Avatar
Default Re: Chipped p28 or p72 for GSR (Jmunk)
Stock GSR Mani = P72
Any other Mani = chipped.
Old Jan 23, 2005 | 08:44 AM
suckawillis's Avatar
Default Re: Chipped p28 or p72 for GSR (Luserkid)
ive ran the gsr with/ without the iab's, and with both a p28 and a p72. i reccomend using the p72 and wire the iab's, unless you get a skunk2/aebs/jg........... intake manifold. its how it is designed to run.
Old Jan 23, 2005 | 04:13 PM
Jmunk's Avatar
Is it worth the investment to get the skunk2 manifold ? Any real gains from running the skunk2 and a chipped p28 ? Will it hurt the car to run a p28 without the knock sensor hooked up ?
Old Jan 23, 2005 | 04:16 PM
NR_hatch's Avatar
Default Re: (Jmunk)
search for info on the IM mani. My buddy has a GSR, ANR mani and JDM ITR ECU and its a real nice set up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Stock GSR Mani = P72
Any other Mani = chipped. </TD></TR></TABLE>
the1337aaron
Sep 14, 2010 05:34 AM
ilovejdmhoes23
Jan 20, 2007 11:52 PM
.I.Need.Money.
Aug 4, 2006 12:42 AM
maxheat
10
Feb 9, 2005 12:55 PM
AzntaggeR
Dec 27, 2003 03:41 AM
