Where to buy Nylon Cheaply ?
Old Jan 23, 2005 | 04:58 AM
Want2race's Avatar
Default Where to buy Nylon Cheaply ?
I have 2 3" round by 1.5" high bushings to make for my Diff.
The problem is that a sheet thats 1ft x1ft and 1.5" thick is like $90...
Anyone know a cheaper way to do this ??
Old Jan 23, 2005 | 05:34 AM
Ca$h's Avatar
Default Re: Where to buy Nylon Cheaply ? (Want2race)
not sure what kind of nylon your looking for but online metals has 1' of 3" round natural nylon for $53. I dont now how much to ship but its a little cheaper than the plate. You know if it needs to be a particular kind of nylon (like a 6, or a 6/6, glass filled)?? If you do I'll see what I can find at work..
Old Jan 23, 2005 | 11:13 AM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by From McMaster Carr &raquo;</TD></TR><TR><TD CLASS="quote">
Part Number 8664K22 $41.18 Each
Form Rods
UL Rating UL 94HB
Material Nylon
Nylon Material Oil-Filled Cast Nylon
Diameter 3"
Diameter Tolerance +.12"
Length 12"
Length Tolerance +1.5"
Opaque Green
Lowest Operating Temperature +0° to +60° F
Highest Operating Temperature +201° to +300° F
Operating Temperature Range +32° to +230° F
Performance Characteristic Electrical Insulator and Flame Retardant and Weather Resistant
Tensile Strength 9500 psi
Impact Strength 1.4 ft.-lbs./in.
Specifications Met Underwriters Laboratories (UL) Ratings
Hardness Rockwell R: 100-115 </TD></TR></TABLE>
Old Jan 23, 2005 | 10:37 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
http://www.msc-direct.com
3" round X 12" length - $29.62
or if its a simple piece, i have a chunk of 3" here. i could turn bushings for you if you need.
Old Jan 24, 2005 | 02:50 PM
Want2race's Avatar
Default Re: (mike_belben@yahoo.com)
Im not seeing it that low.
I need to make 2 diff bushings.. I guess I may just buy the same as stock because I cant find any dense material to use.
Old Jan 24, 2005 | 03:49 PM
they raised the price a bit over the big book that i looked it up in.
http://www1.mscdirect.com/CGI/...96147
part number 63396147 if the link doesnt work.
nylon is pretty damn dense, way harder than rubber motor mounts or even poly bushings by far.
if thats not enough - aluminum, brass, bronze and copper are all options.
Old Jan 24, 2005 | 04:06 PM
Want2race's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike_belben@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote">they raised the price a bit over the big book that i looked it up in.
if thats not enough - aluminum, brass, bronze and copper are all options. </TD></TR></TABLE>
Thanks!
I'm gonna try this.. Should be interesting how I turn it and then find a copper center pin.. I've never made bushings before so it should be interesting
Old Jan 24, 2005 | 04:12 PM
nylon will cut like butter in a lathe, so youll be prone to cut at a high feedrate. restrain yourself, because it can jump right out of the chuck quite easily too.
high spindle speed, go easy on the feedrate. and drilling long lengths makes lots of heat. it will melt to the drill, so use a boring bar or drill with air blowing, etc. i dont know if you should use a lubricant for it.
EMod Civic's Avatar
I've had good luck making mounts using 3M windo-weld urethane. It comes in a caulk tube for around $10. It bonds well to steel, so you can make things like motor mounts pretty easily. It hardens to a very similar stiffness as stock Honda motor mounts, and I haven't had any durability issues in 4+ yrs on my racecar.
-Chris
Old Jan 24, 2005 | 04:30 PM
Ca$h's Avatar
Default Re: (Want2race)
Looked again on onlinemetals.com and you can get 3" diameter x 1.5" length nylon for 8.88 each or Acetal (delrin) for $9.51 ea. Just got to pick the material and go scroll down to the custom cuts section. Still dont know how much shipping would be but I couldn't imagine it being much.
Old Jan 24, 2005 | 07:30 PM
Want2race's Avatar
Default Re: (KP)
From what ive learned it needs to be 6-6 Nylon..
Anyone have an idea where I could find a place that has cutoffs?
i need 2 2"x1" disks.. Almost like hockey pucks!
Old Jan 24, 2005 | 08:47 PM
Bailhatch's Avatar
Default Re: Where to buy Nylon Cheaply ? (EMod Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EMod Civic &raquo;</TD></TR><TR><TD CLASS="quote">I've had good luck making mounts using 3M windo-weld urethane. It comes in a caulk tube for around $10. It bonds well to steel, so you can make things like motor mounts pretty easily. It hardens to a very similar stiffness as stock Honda motor mounts, and I haven't had any durability issues in 4+ yrs on my racecar.
-Chris</TD></TR></TABLE>
i love that stuff! you can easily smooth it out wet so it looks nice too. great to have around the shop
what exactly is the application we are talkign about here, with the nylon?
Old Jan 25, 2005 | 05:27 AM
Want2race's Avatar
Default Re: Where to buy Nylon Cheaply ? (Bailhatch)
Differential bushings on a 500hp car that weighs under 1000lbs!
Old Jan 25, 2005 | 07:14 AM
Bailhatch's Avatar
ooohh nice! something to commute with I presume.
Old Jan 25, 2005 | 02:52 PM
rtype11's Avatar
if you can use delrin I have some kicking around that might work, ill check sizes if you get back to me.
probably harder than Nylon, self lubing etc.... I use it to make sliders for motorcycles and bike knee pads
Old Jan 25, 2005 | 06:33 PM
Formula Racing's Avatar
Default Re: Where to buy Nylon Cheaply ? (rtype11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">if you can use delrin I have some kicking around that might work, ill check sizes if you get back to me.
probably harder than Nylon, self lubing etc.... I use it to make sliders for motorcycles and bike knee pads</TD></TR></TABLE>
That would work.. Please let me know what you got!
Old Jan 26, 2005 | 10:21 AM
rtype11's Avatar
Default Re: Where to buy Nylon Cheaply ? (Formula Racing)
sry i use 1/2' and thinner mosty the closet piece i found was 1X4.4x8" in white.
try finding a GE plasticshapes / polymers close by, they may give you an off cut for free.
maybe you could use this
http://cgi.ebay.com/ws/eBayISA...&rd=1
Old Jan 26, 2005 | 05:23 PM
Want2race's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">sry i use 1/2' and thinner mosty the closet piece i found was 1X4.4x8" in white.
http://cgi.ebay.com/ws/eBayISA...&rd=1 </TD></TR></TABLE>
bought that! thanks
Old Jan 27, 2005 | 04:52 AM
Want2race's Avatar
I presume I can just lathe that stuff right?
Old Jan 27, 2005 | 08:52 AM
rtype11's Avatar
yeah it can be machined very well.
good luck
Old Jan 27, 2005 | 04:40 PM
turbo gli's Avatar
Default Re: (KP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KP &raquo;</TD></TR><TR><TD CLASS="quote">Looked again on onlinemetals.com and you can get 3" diameter x 1.5" length nylon for 8.88 each or Acetal (delrin) for $9.51 ea. Just got to pick the material and go scroll down to the custom cuts section. Still dont know how much shipping would be but I couldn't imagine it being much.</TD></TR></TABLE>
yes get delrin .. good **** .. dense .. and stronger then nylon ..
they use it on all sorts of high strenght app . to suspension bushings ..
bigluelok
Welding / Fabrication
Aug 30, 2008 01:37 AM
danielm3
Feb 3, 2006 08:34 AM
dfoxengr
Jul 1, 2005 06:08 PM
R rated
Apr 23, 2005 06:35 PM
CRVRX
Feb 15, 2004 06:59 AM
